Problem with some BLP files
MentalPower
Post by MentalPower »
Well I can't really describe this with words so I'll just attach some pictures.
This is how it currently looks in XnView:
This is how its supposed to look:
Note: This only happens with some BLP's Also, some BLP's aren't even recognized by XnView and show up in the hex viewer
Any ideas?
V1.90 Alpha
Re: Problem with some BLP files
MentalPower wrote: Note: This only happens with some BLP's Also, some BLP's aren't even recognized by XnView and show up in the hex viewer
Any ideas?
Please send me the files?
MentalPower
Any ideas?
To where?
EDIT: Found your XnView.com address, e-mail sent.
MentalPower
Did you recieve the files?
MentalPower wrote:Did you recieve the files?
Yes, i'll check asap
Wolfmansbro
Post by Wolfmansbro »
thanks for the software, it's an exceptional tool.
I've been having the same problem and am curious if there has been any update on this.
Actual:
From XnView:
Thanks.
Currently impossible to reproduce for other people and me since we do not have the image files.
Move to "Confirmed".
MentalPower
helmut wrote:Currently impossible to reproduce for other people and me since we do not have the image files.
I sent samples of trouble files to Pierre (xnview), and he confirmed them as received in this very thread. Do you need me to send them to another address?
Yes, but i don't know how to read them correctly...
MentalPower
xnview wrote: Yes, but i don't know how to read them correctly...
Please visit: http://wow.curse-gaming.com/en/files/de ... converter/
There you will find the other tool that I'm using to view/convert BLP's, it includes source code in C++. I hope you find the information in it adequate.
Kthana
Post by Kthana »
Some information about the compression used in blp files can be found on http://www.wowwiki.com/BLP_Files and http://en.wikipedia.org/wiki/S3TC.
As far as i can see it's the files that use DXT1 compression. This format uses only 64 bits per block of 4 x 4 pixels, instead of 128 bits used by the DXT2 - 5 compression modes.
Hope this helps you to fix this bug, making this tool even better.
Kthana
Post by Kthana »
[size=0]shameless bump[/size]
Any idea if this will be fixed in the next version?
Do you need some more information to solve this bug?[/i]
yoshimo
Post by yoshimo »
I am also intrested in resolving this issue, i tried several different tools for reading and converting blp files and none of them worked well , some not at all . and the result of xnview with doubled images with stripes and a messed up colour layout is not satisfying either ;)
