I found that XnView have bad GIF format implementation. Try to look at this GIF in for example Firefox and then in XnView, It is GIF with true colors in many frames with 256 colors.
It is from article from czech opensource site Root.cz, where was published article about GIF.
Bad GIF implementation
vykupitel
Drahken
Few (if any) image viewers/editors have a proper gif implementation. View that image in any other viewer/editor and you won't get any better results. The best results come from irfanview, but it keeps animating the pic, jumping back to the begining every time it completes it. Some show only the very first frame, some show nothing but a black screen.
- Forum Librarian
Re: Bad GIF implementation
Coincidently I also took a closer look at this issue a few weeks ago. Here's the original source for that GIF file:
- Philip Howard: Proof that a GIF file can have way more than 256 colors
- True-Color GIF Example (32697 colors, 184565 bytes)
- Alastair Green: Animated Gifs Test
- Google Groups
JohnFredC
No animation
—> JohnFredC
• I've not installed Opera, but I've The Gimp; that pic is displayed OK about the colours,
but here the animation doesn't work
- Gimp says : "Video image"
¤ Else, I guess that the very original GIF features might be retrieved¦applied,
and that we might get rid of the "fake" 8-BPP limitation…
KR
JohnFredC
Well, I was thinking that the animation was an artifact of the method chosen for displaying more than 256 colors. This is a "special case" GIF, after all.
Opera shows the animation. The Gimp seems to hide it, waiting until the paging is complete to display the final image.
I wonder what the creators of that GIF had in mind for the correct rendering...
The correctness of the final image is self-evident once it successfully appears, but is the animation supposed to show, too?
John
- Forum Librarian
Hi John & Clo
Both Jasc Animation Shop 3.11 and Gamani GIF Movie Gear 4.01 have no trouble displaying the file, ...JohnFredC wrote:Opera(!) and theGimp open that GIF file successfully. Nothing else I have does.
... and both programs open it as an animated GIF.JohnFredC wrote:I wonder what the creators of that GIF had in mind for the correct rendering...
gamani (GIF Movie Gear – Support » [url=http://www.gamani.com/gmgsup.htm#browser]Browser Issues[/url]) wrote:No software is perfect, and Web browsers are no exception to this rule. Over the past few years as the Web has developed, popular Web browsers have been inadvertently released with some, um, limitations, in the way they handle GIF animations. The result is that a Web designer, working with pages that will be viewed using a variety of browsers, needs to be aware of things that might not work properly on some viewing setups.
Both NS and IE browsers are not entirely accurate with their timing, especially with very short delays between frames. GIF Movie Gear's playback will often be faster than that of a browser if the delays are shorter than 15/100th of a second. Time for download slows playback even more.
Cheese OR dessert !
—> XnTriq
Hello !
It shows it only as 8-BPP!
- Hence, I get only cheese OR dessert, not both…
kR
• I've not the Jasc soft, but I've MovieGear and it displays the animation, but does NOT show the right colour-depth !Both Jasc Animation Shop 3.11 and Gamani GIF Movie Gear 4.01 have no trouble displaying the file
