I want to run XnView from USB Stick. Is this possible ?
Or does XnView write during Installation some DLLs into the
Win system directories or need some Registry values ?
Where are the settings stored?
In the Registry or ina *.ini file in the installation directory?
Is XnView completely portable / runnable from USB Stick ?
pstein
Re: Is XnView completely portable / runnable from USB Stick
If you use .ini, xnview doesn't use registry, and installation don't write dll in system folderpstein wrote:I want to run XnView from USB Stick. Is this possible ?
pstein
Olivier_G
The default settings in Options>Install are:
- Use Windows folder to save INI file: unchecked
- Use registry to save options: unchecked
With those settings, the xnview.ini file should be in your XnView installation folder.
(you can also create an empty xnview.ini file or put an existing one in the same directory as your xnview.exe)
Check those FAQ: Minimal installation and Technical info about XnView's settings (store & load).
Olivier
