Geotagging EXIF exact coordinates
vido
Post by vido »
Hi!
I've geotagged some photos and would like to see the information in XnView. I can find the Geotag Exif information in the properties of the image. But the numbers show only full latitude and longitude information and no exact ones in decimal or minute/second form.
For example XnView shows latitude: 26 and longitude: 65 and not 26.84 and 65.22.
I know it's some very small issue but I wanted to mention it here.
Thanks for your really nice program!
Re: Geotagging EXIF exact coordinates
vido wrote:Hi!
Could you send me a sample with EXIF geotag, please?
vido
Post by vido »
d'accord. i've send you an example photo by mail.
merci.
Post by Guest »
xnview wrote:
vido wrote:Hi!
J'ai le même problème, afin de récupérer ces données en CSV. Avez-vous une solution ?
