Windows Ico shows pink where transparency expected
iconantsy
Post by iconantsy »
I tried converting a gif (with transparent background)
to a .ico windows icon file. The transparency seems
to show up fine, because the background is indeed
transparent when I set explorer's window background
to anything other than white... but when the background
is white, it shows pink where it should be transparent...
Does anybody know why? This doesn't happen
when I create the icon using visual studio... this
is a 256 color 48x48 ico file
Thanks alot
Re: Windows Ico shows pink where transparency expected
When converting a GIF or a palette-based PNG image to the Windows ICO, CUR and ANI formats, one has to ensure that the palette contains 100% black (R0/G0/B0) and 100% white (R255/G255/B255), even if black & white aren't used in the actual image.
