Transparent PNG + ICO are not supported in ALL 5 Modes:
- Thumbnail
- Preview
- View
- Convert
- Saving
Transparent GIFs are not supported in:
- Thumnail
- Preview
In other word, the Alpha-Channel (transparency) is total missing in all image formats.
A modern image viewer MUST be able to full support at least the 3 most common used formats like PNG/GIF/ICO. What the pite, that is not the case of XnView. This issue is already talked/confirmed in here since 1 years ago but still not getting fixed.
Test:
http://www.aadmm.de/de/dtdform.xml
XnView does not support transparent PNG, ICO, GIF!
Re: XnView does not support transparent PNG, ICO, GIF!
Sorry but transparent gif & png are supported in viewer, and will be in preview. Do you have enabled transparency in options?mrgreen wrote:Transparent PNG + ICO are not supported in ALL 5 Modes:
- Thumbnail
- Preview
- View
- Convert
- Saving
- Thumnail
- Preview
Test:
mrgreen
Ok, for thumbnail it's currently normal, and preview is modified.Anonymous wrote:I have forgetten to tell you my system:
Windows XP with Visual Style (Apple look) + Service pack 2
In view for 32bits picture, you have menu view/Show Mask - combien alpha
Perhaps it would be great to have only one option for 8bits + transparency index & 32 bits alpha pictures??
Option in Read/PNG affect the loading not displaying, you 32bits picture will be converted in 24bits, so do not selected it...
mrgreen
What do you mean modified??
These are real screenshots and not a artwork modified to fool you here, with all respect sir.
I have tried all combinations as you said, nothing work. This problem has been confirmed by a lot of people in here. not me alone.
To be honest, have you EVER tested these images to compare to my results? I think no.
Please make me an screenshot with this image in your Thumbnail/Preview/View Panel:
http://www.aadmm.de/images/png-alpha-2.png
Thank you.
Thank you.
Sorry, is modified in next releasemrgreen wrote:> and preview is modified.
If you uncheck option/PNG/Combine 32bits, here is the result:These are real screenshots and not a artwork modified to fool you here, with all respect sir.
But one little problem is that currently i use always black as background color, not view background color... I have changed that...
But maybe there is a way to configure transparency view.
Currently we have option/View/Use transparency (for 8bits picture with transparency index) and View/Combine mask for 32bits picture!
So what is the best an option 'Use transparency' in option/view or in menu View??
mrgreen
Sorry Pierre for the missunderstanding!! it was my mistake.
From the 3 first transparent .png in your screenshots, i have also the exactly result like you. The transparent areas will be either substituted with white, black or other background color. No transparency also.
For the last .gif image, i also have the same result like you. The transparency support in View panel is working well here. It lacks only a little bite in preview and thumbnail modus, but as you said it will be fixed in the next version.
From my point of view, i would say to use the option 'Use transparency' for the flexibility and comfort reasons rather than using menu/view. For the menu/view the user have to change modus for single image and when someone has a big collection of images, then it is not really useful to change by hand. The other argument is, Alpha channel will be rarely specific changed by the user when they view/browser images. The most of images viewer i know have either no extra option to change (the Alpha channel is hardcoded in the program by default) or they have an fixed option in the menu/option for transparancy. XnView is rather an image viewer for quick browsing in daily work than a image processing program like photoshop/Gif-animator where user need specific view modus to view thought the menu/view for the single image. And the last argument is, png/gif/ico are the most used formats, no user would need to change the view modus everyday, so if needed you can even hardcoded for the Alpha-channel without any option. Every images of such format will show "as it" (as original with transparency) like the Windows build-in Fax viewer.
Just my personal opinion
Have a nice day...
Have a nice day...
