Multi convert transformations: Resize parameters
Quite often I use the multi convert for resizing multiple images. This can be done simply by adding the "Resize" transformation in the transformation tab and setting a resize value.
Whenever adding the "Resize" transformation to the list of transformations, the resampling is set to "Bi-Linear". Instead, resampling should default to "Lanczos" (like in the resize dialog for single image resizing) or even better to the resampling last used.
Olivier_G
Re: Multi convert transformations: Resize parameters
Post by Olivier_G »
helmut wrote:or even better to the resampling last used.
I support this.
Olivier
