ToDo list
Paul Coddington
Re: ToDo list
"INI in program folder"
Shouldn't that be %APPDATA%\* folder? The program folder is not writable and is shared by all users.
Peter2
Re: ToDo list
That depends on your system. 'Program folder' is helpful if you use the program in portable mode.Paul Coddington wrote:...The program folder is not writable and is shared by all users.
Peter
juan_tico
Re: ToDo list
Hi guys!
Great job with this software so far.
I'd like to see the option to start the renaming batch with an index number "#">1.
For details please see this post:
http://newsgroup.xnview.com/viewtopic.p ... 05#p123905
Cheers!
Cheers!
Alt Bass
Re: ToDo list
I would love to see "assign profile" as a part of "ICC convert" (as an item in "rendering intent" or as a checkbox which disables "input profile) and "rendering intent" elements).
Kola
Re: ToDo list
Autocrop is a cool feature but, I think, it needs an option "Offset" (or something named like). If one need to autocrop pictures with some border padding he can use autocrop action and relative canvas resize next. But if background colors of images in a batch are not the same it won't work correct. So it should be an option to crop all background but a number (offset) of pixels near the picture itself.
bar_foo
Re: ToDo list
One small suggestion: if XnConvert is set to skip existing filenames, check whether the file exists already before doing any other processing, and if it does then just move on to the next file. This could save a huge amount of time, for example when creating a folder mirroring another with resized images.
olcifaraga
Re: ToDo list
Crop with percentage not only pixels. its needed.
For example; when cropping scanned files borders with different papersizes.
Irving
Re: ToDo list
Find Dominique' Clement and ask her to update Toolbar 4.
ssjoco
Re: ToDo list
Keep EXIF data when convert jpeg to WebP
wfa
Re: ToDo list
Support for flipping pages in multipage file like pdf in Actions tab. This helps seeing the effects on pages of the pdf file other than the first.
wfa
Re: ToDo list
A way to pick a "from" color from the image on the right for the "Replace color" action.
Re: ToDo list
wfa wrote: Tue Jan 15, 2019 8:42 pm Support for flipping pages in multipage file like pdf in Actions tab. This helps seeing the effects on pages of the pdf file other than the first.
A way to preview the effect of the selected action(s) on the pages of a multipage file?
+1
Re: ToDo list
A 'color picker' ?wfa wrote: Tue Jan 15, 2019 8:45 pm A way to pick a "from" color from the image on the right for the "Replace color" action.
wfa
wfa
Re: ToDo list
Add to Text action:
Proportional text size based on the image dimension. This prevents long text (in case of for example Folder name) from going outside the image.
