SVG thumbnails of white designs
m.Th.
Re: SVG thumbnails of white designs
Post by m.Th. »
+1 for Alpha (transparency) channel support.
...agree with XnTriq's observations above.
m. Th.
m.Th.
Post by m.Th. »
Perhaps is better to note: The background should have the classical "transparent color" popularized by Photoshop
See here: http://adgcreative.net/blog/wp-content/ ... incoln.png
m. Th.
Shores
Post by Shores »
In latest 0.85 x64 even the preview pane shows a full white image, not only for white SVGs, but for all SVGs.
Opening the image works ok, but always shows a white background.
Shores
Post by Shores »
In latest 0.86 x64 the preview pane works again for svgs, but still with white background, so that white svg designs show a full white preview.
Even opening the svg shows a full white image for white SVG designs.
Shores
Post by Shores »
Still nothing in v0.87 x64, all white images for white svgs, in thumbnail, preview pane and opened image...
Shores wrote: Just to ask, will it be implemented or not?
thanks!
Shores wrote:Still nothing in v0.87 x64, all white images for white svgs, in thumbnail, preview pane and opened image...
thanks!
in IE or firefox, your svg is white too
Shores
Post by Shores »
Maybe I'm not being clear: the SVG IS a white pushpin icon, but it has TRANSPARENT background, as you can clearly see here:
http://www.atipica.it/clienti/svgtest/pushpin.html
The problem is that XnView MP shows the white pushpin on a WHITE BACKGROUND, which is not correct: as in transparent PNGs, the transparent background should be rendered with a checkered pattern, or at least we should be able to choose a different color...
Shores wrote:Maybe I'm not being clear: the SVG IS a white pushpin icon, but it has TRANSPARENT background, as you can clearly see here:
QT Lib has a limited SVG support, it seems that for this file the transparetn background is not rendered correctly
Shores
Post by Shores »
So you're saying that you've got other SVG files with transparent backgrounds that do get rendered correctly?
Could you please post one of them here?
Or could it be a bug just like this one:
https://forum.qt.io/topic/14762/solved- ... background
Ok, i've found the problem, a change in a previous version. It will be fixed in 0.88
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
Shores
Post by Shores »
Now it's working properly, and shows a checked background under the SVG graphic, even when the graphic is not white, but the background doesn't respect its settings (tools, settings, view, view, use checkboard pattern+colors+size), neither in the browser nor in the single file view.
