Addons/Plugins/...
Peter2
Re: Addons/Plugins/...
Post by Peter2 »
sunnywilson09 wrote: Sun Apr 12, 2020 9:22 pm I can't get the FTP plugin to work though. I extracted it to the addons folder, opened an image, but can't find the ftp option in view mode.
In "View Mode" it is in menu "Filter", in Browser Mode it is under "Tools - Plugins".
Do you don't find the commands or to you see no dialogue or is there no reaction of the dialogue?
olivex
Post by olivex »
HEIC plugin seems not working with 2.49.4. Double clicking an HEIC image only brings up the main interface. Preview still works but it won't open the image
Peter2
Post by Peter2 »
olivex wrote: Thu Dec 31, 2020 12:58 pm HEIC plugin seems not working with 2.49.4. ...
Yes, confirmed..
Peter2 wrote: Fri Jan 15, 2021 9:57 pm
Yes, confirmed..
yes a fixed version will be soon available
olivex
Post by olivex »
xnview wrote: Mon Jan 18, 2021 4:30 pm
Yes, confirmed..
It seems 2.49.5 fixed this bug but one question, what is the b4bit plugin for? It seems there is no 64bit XnView.
olivex wrote: Wed Feb 17, 2021 4:34 am It seems 2.49.5 fixed this bug but one question, what is the b4bit plugin for? It seems there is no 64bit XnView.
For XnView MP 64bits
olivex
Post by olivex »
It seems the bug was not fully fixed. I cannot double-click an HEIC file to open it, neither can I right click an HEIC file and open with XnView. I have to browse to it and open it inside XnView.
olivex
Post by olivex »
Besides, displaying HEIC (in browser view) is very slow.
olivex wrote: Wed Feb 17, 2021 3:40 pm It seems the bug was not fully fixed. I cannot double-click an HEIC file to open it, neither can I right click an HEIC file and open with XnView. I have to browse to it and open it inside XnView.
please check your registry entry for heic
olivex
Post by olivex »
xnview wrote: Wed Feb 17, 2021 4:52 pm
How to check this? I'm using portable version.
olivex
Post by olivex »
Do you mean XnView.ini? There is no HEIC in plugins section. Do I need to add one? How to do this? I just decompressed HEIC zip files in plugins folder.
olivex wrote: Sun Feb 21, 2021 1:57 pm Do you mean XnView.ini? There is no HEIC in plugins section. Do I need to add one? How to do this? I just decompressed HEIC zip files in plugins folder.
In XnView, are you able to load a HEIC file?
olivex
Post by olivex »
xnview wrote: Mon Feb 22, 2021 10:27 am
In XnView browser, yes I can browse to the HEIC file and open it. But if I directly double click the HEIC file in Windows Explorer, it will not open the HEIC file. In stead, it only brings up the XnView browser.
For jpg or other format file I can double click it in Windows Explorer to open it in XnView.
olivex
Post by olivex »
olivex wrote: Mon Mar 08, 2021 2:41 am
Is this consider normal?
olivex wrote: Mon Mar 08, 2021 2:41 am In XnView browser, yes I can browse to the HEIC file and open it. But if I directly double click the HEIC file in Windows Explorer, it will not open the HEIC file. In stead, it only brings up the XnView browser.
It seems that you have a problem in registry with associations
