EXIF lossless rotation
tolika
Post by tolika »
Hi all,
Recently I have moved to Linux.
In Linux version I can't find the "Rotate using EXIF".
May be I am missing something?
BeNiSh
Re: EXIF lossless rotation
Post by BeNiSh »
is this function already build in? where can I find it? I have XnView 1.98
Tools>Lossless transformations
BeNiSh
Post by BeNiSh »
thx, but I wrote about function "Define picture Orientation", it should mean function for editing just EXIF orientation value and thats fucntion isnt in XnView ... I think. I must rotate picture in XnView and EXIF modify by EXIFeditor (http://www.kiwiczech.net/index.php?menu=353&sub=4)
In the exif panel, you can double click to change exif orientation
BeNiSh
Post by BeNiSh »
aaaaaaa here is this fucntion. I still searching it in right click / properties / EXIF and there is imposible change it :) thx for advice
is there way how can I modify orientation value for more selected pictures in one click?
SpeedDevil
Post by SpeedDevil »
xnview wrote:In the exif panel, you can double click to change exif orientation
Where is this panel?
The preview panel with preview/EXIF/IPTC/...
