Toolbar skins for XnView Classic
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
Mr.Pit
Re: Toolbar skins
Post by Mr.Pit »
XnTriq wrote:[:arrow: Use the Mezich Skin as default
This does not answer my question. I don't like the Mezich skin or one of the others, I always used the XP skin!
Pit
BTW Pierre: it would be nice to have copy and paste in the right-klick menu...
Re: Toolbar skins
Mr.Pit wrote:This does not answer my question.
Image Of course it does! You were asking “what happend to the others”.
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=53737#53737]Use the Mezich Skin as default[/url]) wrote:
Troken wrote:
ckit wrote:Actually I'd like to see all skins removed from XnView and instead packaged into separate ZIP archives.
I totally agree, some skins look very unprofessional and/or childish, could IMO be removed from the program.
So my question is, which skins must be in the package?
Mr.Pit
Re: Toolbar skins
Post by Mr.Pit »
XnTriq wrote:Image Of course it does! You were asking “what happend to the others”.
Sorry, I did not recognize this as a link.
Pit
Error404
Post by Error404 »
Any intentions on updating these images' links? They're all broken now. :(
Or, i dunno, if someone could point out a good skin with small buttons (like Phoenix small), i'd be much gratefull. :D
Error404 wrote:Any intentions on updating these images' links? They're all broken now. :(
Broken??? I have no problem
Error404
Post by Error404 »
They work now... must've been something temporary... maybe a route problem.
Thanks! :D
"Disabled" bitmap no more supported ?
:arrow: Pierre
:) Hello !
• I attempted to make a "sepia" «disabled=…» main bitmap for a skin of mine as a test and to get a certain look,
that doesn't work anymore with that entry in the <info.txt> file.
- The built-in feature that makes the inactive icons greyed takes precedence always, it seems.
:mrgreen: KR
BUUUUMMMMPPPPPPP !
:arrow: Pierre
:) Hello !
• Please, some info ? >>> Image <<<
:mrgreen: KR
herr_k.
Post by herr_k. »
hi,
when using the gnome set, the back&forth arrows are missing.
can this be solved somehow?
OUTDATED !
:arrow: herr_k
:) Hello !
• The "small" bitmap of the skin you show seems quite outdated. You could complete it following the info we give HERE :wink:
- Please, don't forget to update the <info.txt> file as
version=3
• Good luck :D
EDIT :   BTW, I checked that skin, 3 icons are missing in the browser bitmap…
- Moreover, I'm not sure at all that the main bitmap is OK for a current use…
- This skin could be valid till the 1.80… versions only, as far as I see here…
:mrgreen: VG
herr_k.
Post by herr_k. »
urgs, thanks clo,
if i start this, i would probably end up making a complete new toolbar ;)
maybe if i have time some time..
Re: BUUUUMMMMPPPPPPP !
Clo wrote: • Please, some info ? >>> Image <<<
Yes normal, the disabled bitmap is no more used
Some of the old skins may not look that professional and are incomplete. Nevertheless, is there a simple, "official" way to download and include them into XnView? (It's good to have an overview of all skins in the initial post, but download links and a description for installing should be provided.)
Update for 1.95xx
:arrow: All
:) Hello !
• With the 1.95 new "beta" versions, the skins have been changed by adding twelve icons…
• I updated a bunch of my own skins to test, they are available from THIS PAGE.
• FYI, please, see also THAT MESSAGE
- The instructions to make skins are updated too in our Manual (online and to download).
:mrgreen: KR
Dstruct
Re: Toolbar skin
Post by Dstruct »
xnview wrote:Mezich toolbar will be default in a future version...
Any chance to get it working properly on 24bit Dektop (Windows XP Prof.)?
FIXED (1.96)
