Notepad++ (Opensource Freeware)
All non-XnView related: softwares, formats, imaging, photography...
ckit
Post by ckit »
Notepad++ v5.0.3 fixed bugs and added features (from v5.0.2) :
1. Fix crash bug while processing find in all opened files/find in files in a file contains a very long line.
2. Fix the display problem in found results dialog while processing find in all opened files/find in files in a file contains a very long line.
3. Fix not remembering the history file setting "Don't check at launch time" option bug.
Notepad++ v5.0.2 fixed bugs and added features (from v5.0.1) :
1. Fix crash bug for tags match highlighting.
2. Fix the huge file makes notepad++ crash issue.
3. Fix adding item in the history file list while deleting file from Notepad++ bug.
4. Fix a bug that file detection options set are not saved due to doc monitor plugin.
5. Improve opening file performance.
6. Fix bug when closing file using close button.
ckit
Post by ckit »
Notepad++ v5.1.1 fixed bugs (from v5.1) :
1. Fix Unicode version display Korean/Japanese language problem.
2. Fix bug : Open in new instance not allowing spaces in paths.
3. Fix "Global Styles" string incorrectly displayed in Unicode version.
4. Fix filters for open/save dialog not showing or incorrectly (showing 'L').
5. Fix calltip argument with 'L' leader character bug.
6. Fix tab control draw bug.
Notepad++ v5.1 fixed bugs and added features (from v5.0.3) :
1. Make Notepad++ Unicode-compliant application(Unicode path supported).
2. Fix crash issue due to the incoherent modification/creation date.
3. Enhance Find in files feature : launch in thread, stop as wish.
4. Add find/replace dialog memorize capacity.
5. Fix "find in all opened files" and "find in files" unicode text search bug.
6. Fix "replace" and "replace all" bug.
7. Fix tag match highlighting mismatched bug.
8. Make tag match highlighting on non html zone optional.
9. Fix cpu high consumption bug while document is cloned with smart highlighting and xml matched highlighting features activating.
10. Refine the Save/Open file directory settings (follow tab/last operation/user defined dir).
11. Add "Doc go to new instance" and "Doc open in new instance" features.
12. Move document to another instance of Notepad++ via drag and drop document tab.
13. Add new pluin notification NPPN_DOCACTIVATED and NPPN_LANGCHANGED.
14. Fix context menu incorrect setting crash bug.
15. Fix crash problem while typing Chinese character in ANSI CSS document under Chinese environment.
16. Fix a problem with Incremental search+UTF8 in win9x.
17. Fix the User defined language not working in Unicode version bug.
18. Fix bug with CPP lexer keyword list.
19. Fix auto-completion not woring for HTML, SQL and RC problem.
20. Fix html, sql and rc auto-completion bug.
21. Fix cancel to save file in Notepad++ can not stop system shutdown problem.
22. Fix bug with opening relative path files.
23. Fix bug with clearing read-only flag.
24. Fix wrap after save as bug.
25. Improve "reload from disk" behaviour.
26. Add option to only show the filename in the titlebar.
27. Add NPPM_[G/S]ET_BUFFERLANGTYPE, NPPM_[G/S]ET_BUFFERENCODING, NPPM_[G/S]ET_BUFFERFORMAT messages to access buffer properties.
28. Remove all the comic sans font (finally :) ).
Included plugins (Unicode):
1. MIME Tools v1.5
2. NppExport v0.2.8
3. Doc Monitor v2.2
4. NppAutoIndent 1.2
5. FTP_synchronize v0.9.6
6. NppAutoIndent 1.2
7. NppNetNote v0.1
8. TexFX v0.24a
Included plugins (ANSI):
1. TexFX v0.24a
2. NppExec v0.25R2
3. Spell Checker v1.3.1
4. MIME Tools v1.5
6. NppExport v0.2.8
7. Compare plugin v1.5.1
8. Light Explorer v1.5
9. Doc Monitor v2.2
10. NppAutoIndent 1.2
11. NppNetNote v0.1
ckit
Re: Notepad++ (Opensource Freeware)
Post by ckit »
In this new release, a line change state vertical bar is added. However, it has a bug during the redo action. I'll try to fix it in the next release.
Here are Notepad++ v5.3 new features and fixed bugs (from v5.2) :
1. Add Line change state vertical bar.
2. Drop (or open in dos command line) a directory in Notepad++ to open all files in the directory recursively.
3. Add "Find all in current file" feature.
4. (Most of) Find/replace dialog settings are remembered.
5. Add a hidden setting (dlgAlwaysVisible in config.xml) to allow user set it manually to not hide the Find/Replace dialog if any result found.
6. Fix uncomment block erasing first character bug.
7. Enlarge some strings displayed zone for the translation.
8. Fix ESC key for column mode behaviour.
9. Fix read only file SaveAs bug.
10. Change behaviour : no popup dialog while closing an unsaved empty untitled document.
11. Changing "Search result" stylers via Styler Configurator takes visual effect on the fly now.
12. Fix for L_EXTERNAL in loadSession.
13. Variable $(CURRENT_WORD) is enlarged to 2039 charraters.
14. Fix the bug the Notepad++ is launched several instances but show nothing.
15. Fix Find in files regression : The result panel doesn't show Unicode characters correctly.
1. TextFX v0.26
2. NppExec v0.3 RC1
3. Spell Checker v1.3.2
4. MIME Tools v1.5
6. NppExport v0.2.8
7. Doc Monitor v2.2
8. NppNetNote v0.1
1. TextFX v0.25
2. NppExec v0.3 RC1
4. MIME Tools v1.5
6. NppExport v0.2.8
7. Light Explorer v1.5
8. Doc Monitor v2.2
9. NppNetNote v0.1
ckit
Post by ckit »
Version 5.3.1 is available now.
In this release, a serious bug of inaccurate replace bug is fixed.
7z format distribution is included in both binary and source release due to its superior algorithm. Their contents are the same as zip packages. If you don't know what is 7z, just download zip packages.
Here are v5.3.1 new features and fixed bugs (from v5.3) :
1. Fix inaccurate replace bug.
2. Increase "Find what" and "replace with" fields to 2047 characters in Find/Replace dialog.
3. Stop the indicator highlighting while the line change marker margin is hidden.
4. SConstruct and SConscript are recognized as python file.
1. TextFX v0.26
2. NppExec v0.3 RC1
4. MIME Tools v1.5
6. NppExport v0.2.8
7. Doc Monitor v2.2
8. NppNetNote v0.1
1. TextFX v0.25
2. NppExec v0.3 RC1
4. MIME Tools v1.5
6. NppExport v0.2.8
8. Doc Monitor v2.2
9. NppNetNote v0.1
