AIMP2 - better alternative for WinAmp
All non-XnView related: softwares, formats, imaging, photography...
Dreamer
Post by Dreamer »
AIMP v2.11 has been released.
Player
+ AutoJump to the next file in tag editor was added
+ Selection in playlist will move to the current file regardless of the focus if manual navigation used
+ Function of template formation was speeded up
+ Arabic and Belarussian (true) localizations were added
Fixed
- Bug in CUE-Parser
- Bug with Playlist selection in autojump to next playlist function
- Bug with playlist window position in dualview mode
- Bug with QuickFileInfo updating
- Bug with crossfade between tracks with active Mute or PreAMP modes
- Bug with randomize by playlist function in DragNDrop Mode
- Bug with playing of multichannel audio
- Bug with tracklist genereation by template
Dreamer
Happy User of Aimp2
Post by Happy User of Aimp2 »
Indeed the best player. Thank you for the skins. =)
Post by Guest »
4 sure... the best player! aimp > winamp easylly :)
Dreamer
Post by Dreamer »
Dreamer
Virtual_ManPL
AIMP 2.5 Beta Public Testing
Post by Virtual_ManPL »
Virtual_ManPL
ckit
Post by ckit »
Anyone know how to get Logitech's Setpoint software to use AIMP2 as the Media Player?
I already know how to edit the "players.ini" file, just need the right code to inject into it.
Dreamer
Post by Dreamer »
Don't know, but you could try HotkeyP.
Dreamer
ckit
Post by ckit »
Ok I think I've fixed it with the following changes to the Players.ini...
#List of supported players
#{btn|key|msg|emg|cmd|wac},exeName,wndClass,wndCaption,xxx,play_delayplay,pause,stop,prev,next,remove_flags,ShowOSD,menu_item
[Players]
MSMedia9=wac,wmplayer.exe,WMPlayerApp,Windows Media Player,xxx,xxx,xxx,xxx,xxx,xxx,0,1,Windows Media Player 9
MSMedia7=wac,wmplayer.exe,WMP Skin Host,Windows Media Player,xxx,xxx,xxx,xxx,xxx,xxx,0,1,Windows Media Player 7
MSMediaX=wac,mplayer2.exe,WMP Skin Host,Windows Media Player,xxx,xxx,xxx,xxx,xxx,xxx,0,1,Windows Media Player
MusicMatch7=wac,MMJB.EXE,MMJB:MAINWND,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,MusicMatch
MusicMatch=cmd,MMJB.EXE,xxx,MusicMatch Jukebox 4,xxx,0x101F4,0x18059,0x101F5,0x101F6,0x101F7,0,1,MusicMatch
MDesktop=wac,MDesktop.exe,MediaDesktopClass,Media Desktop,xxx,xxx,xxx,xxx,xxx,xxx,0,1,Media Desktop
PowerDVD=key,PowerDVD.exe,xxx,CyberLink PowerDVD,xxx,0x0d,0x20,S,P,N,0,1,Power DVD
WinDVD=wac,WinDVD.exe,WinDVDClass,Player,xxx,xxx,xxx,xxx,xxx,xxx,0,1,Win DVD
WinDVD4=key,WinDVD.exe,WinDVDClass,InterVideo WinDVD 4,xxx,0x0d,0x20,0x23,0x21,0x22,0,1,Win DVD
WinDVD5=key,WinDVD.exe,WinDVDClass,InterVideo WinDVD 5,xxx,0x0d,0x20,0x23,0x21,0x22,0,1,Win DVD
WinDVD6=key,WinDVD.exe,WinDVDClass,InterVideo WinDVD 6,xxx,0x0d,0x20,0x23,0x21,0x22,0,1,Win DVD
WinDVD7=key,WinDVD.exe,WinDVDClass,InterVideo WinDVD 7,xxx,0x0d,0x20,0x23,0x21,0x22,0,1,Win DVD
iTunes=wac,iTunes.exe,iTunes,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,iTunes
MediaCenter=wac,ehshell.exe,eHome Render Window,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,Windows Media Center
WinAmp3=key,studio.exe,STUDIO,xxx,xxx,X,C,V,Z,B,0,1,WinAmp 3
WinAmp3d=key,winamp3.exe,STUDIO,xxx,xxx,X,C,V,Z,B,0,1,WinAmp 3d
Rhapsody=key,Rhapsody.exe,xxx,Rhapsody,xxx,^P,^P,^S,^B,^F,0,1,Rhapsody
YahooMusicEngine=key,YahooMusicEngine.exe,YMPFrame,xxx,xxx,^ ,^ ,^S,~0x25,~0x27,0,1,Yahoo! Music Jukebox
RealOne=wac,realplay.exe,GeminiWindowClass,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,RealOne Player
WinAmp5=cmd,winamp.exe,Winamp v1.x,xxx,xxx,40045,40046,40047,40044,40048,0,1,WinAmp 5
MediaLife=key,Medialife.exe,MediaLife Frame class,Logitech MediaLife,xxx, , ,S,P,N,0,1,MediaLife
MediaLife4=wac,Medialife.exe,MediaLife Koan GDI Class,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,MediaLife
PLAYDVD=key,PlayDVD.exe,PlayDVD Frame class,Play DVD,xxx, , ,S,P,N,0,1,PlayDVD
foobar2000=cmd,foobar2000.exe,{DA7CD0DE-1602-45e6-89A1-C2CA151E008E}/1,xxx,xxx,40009,40044,40010,40051,40011,0,1,foobar2000
AIMP2=cmd,aimp2.exe,Winamp v1.x,xxx,xxx,40045,40046,40047,40044,40048,0,1,AIMP 2
[Players.Run]
MediaCenter=path,$WINDOWS\eHome
WinAmp3=reg,HKLM,SOFTWARE\Classes\Winamp3.File\DefaultIcon,,2
Rhapsody=reg,HKCR,rhap\DefaultIcon,,5
WinAmp5=reg,HKLM,SOFTWARE\Classes\Winamp.File\DefaultIcon,,2
foobar2000=path,C:\Program Files\foobar2000
AIMP2=path,C:\Program Files\AIMP2
[Players.Display]
MediaCenter=Windows Media Center
RealOne=RealOne Player
WinDVD=WinDVD
WinDVD4=WinDVD4
WinDVD5=WinDVD5
WinDVD6=WinDVD6
WinDVD7=WinDVD7
MediaLife=MediaLife
PLAYDVD=PlayDVD
foobar2000=foobar2000
AIMP2=AIMP 2
Aokromes
Post by Aokromes »
Aokromes
Post by Aokromes »
legithrand
Post by legithrand »
Aokromes, can you post the changes that have been made for 2.5?
Dreamer
Post by Dreamer »
History
AIMP v2.50 (07.07.2008)
+ Player: "Stop" button blinking then option "Stoped after track played" is on
+ Player: Ability of autosaving playlists with the path it was opened from (previously it was saving to the profile folder)
+ Player: Ability to order code table to none-Unicode strings
+ Player: Ability to use "if" statement in string masks
+ Player: Autosave queue after closing AIMP
+ Player: Displaying of player status in tray hint
+ Player: Displaying of true track names instead of signs "next / previous file" on navigation buttons
+ Player: Genres are sorted by name
+ Player: Main windows transparency settings extended
+ Player: MIDI / MOD files play options
+ Player: New play / capture Internet-radio module
+ Player: New settings screen ergonomics
+ Player: Update of function "copy to folder" - "recent folders" list added
+ Playlists: Automatic sort playlist function with window "Playlist Customization"
+ Playlists: Cut file from playlist if D'n'D & press Alt
+ Playlists: Data caching reduced
+ Playlists: Load / Save playlist's operations accelerated
+ Playlists: M3U8 playlists support
+ Playlists: Now you can add a few folders at once using dialog window
+ Playlists: Now you can hide enable/disable track buttons in playlist
+ Playlists: Programm's code optimization
+ Playlists: Scrolling playlist bookmarks by mouse wheel
+ Playlists: Show marks in Playlist (requires AudioLibrary plugin)
+ Playlists: The playlist name becomes folder name if folder added
+ Advanced Search: Ability to set lists for file search
+ Advanced Search: Displaying of file number in order
+ Bookmarks manager: View preference
+ Core: Ability to add your owen bookmarks to options
+ Core: Ability to wirk with playlist's Save/Load functions
+ Core: Added two playback modes of CUE-lists
+ Core: Advanced playlist's abilities
+ Core: BASS v2.4 engine support
+ Core: New abilities for Addon-plugins
+ Core: New PluginController
+ Core: New Winamp Input Wrapper
+ HotKey Manager: Ability to set both global and local keys for all functions
+ HotKey Manager: Improved Multimedia keys working
+ DSP Engine: Channel reversing filter added (for stereo only)
+ DSP Engine: Enhancer filter added (for stereo only)
+ DSP Engine: Improved equalizer filter
+ DSP Engine: Improved work with Winamp DSP
+ DSP Engine: Logarithmic volume control added
+ DSP Engine: Silence skip (then playing) filter added
+ DSP Engine: Sound normalization filter added
+ DSP Engine: Voice removing filter added
+ SkinEngine: Added ability to add buttons / ńheck box / scrollbars
+ SkinEngine: Added ability to align elements with "centre"
+ SkinEngine: Added ability to align text in labels
+ SkinEngine: Programm's code optimization
+ Advanced Tag Editor: Ability to remove tags of several files
+ Advanced Tag Editor: Ability to set cover to several files
+ Advanced Tag Editor: Ability to edit MPC / AAC tags
+ Advanced Tag Editor: Added AutoTag function
+ Advanced Tag Editor: New interface
+ Advanced Tag Editor: Programm's code optimization
+ Audio Library: Ability to choose table column's position
+ Audio Library: Expanded fusion with player
+ Audio Library: FLAC / APE / MPC / AAC support
+ Audio Library: New DB service menu
+ Audio Library: New library interface
+ Audio Library: Quick navigation panel
+ Audio Library: Quick search in grouping tree
+ Audio Library: Saving relative file paths from removable drives
+ Audio Converter: FLAC, AAC, MPC/MP+ added
+ Audio Converter: Lame encoder updated to v3.98
+ Audio Converter: New converter engine
+ Audio Converter: New interface
+ Audio Converter: Switched on command-line coders
+ Quick Tag Editor: Copy data to buffer button added
+ Quick Tag Editor: Copy file to buffer button added
+ Quick Tag Editor: Autofill tags function from file name / file's path
+ Quick Tag Editor: New design
BTW - It's still NOT the final version.
Dreamer
A guy
Newer skin pack
Post by A guy »
Could you make a newer skin pack please?
Dreamer
Post by Dreamer »
I'm a bit busy now, sorry, but perhaps later (when official version 2.5 will be released)...
Dreamer
