Hotkeys / Shortcuts Requests
New "already implemented" hotkeys / shortcuts in version 1.80.
- Zoom in/out in viewer and fullscreen - RMB+Wheel, LMB+Wheel
- Lock Zoom - RMB+MMB, LMB+MMB
- Reset size and position - RMB+LBM, LMB+RMB
- Compare - Shift+C, Ctrl+F10
- Generate File Listing - Shift+L, Ctrl+M
- Open - System - F3
- Edit - System - F4
- Full Screen - change from Ctrl+F to F
- Search - change from F3 to Ctrl+F
- Go to fullscreen (also from the browser with F11 only) - F and F11
- Toggle views - F9
- Options - F12
- Slideshow start/stop - Space, Pause
- Create new folder - F7
- Add Text... - Shift+T
- Canvas size - Shift+C
- Automatic crop - Shift+Y
- Properties - Alt+Enter
- Red Eye Correction - change from Alt+E to Ctrl+E
- Rotate - Shift+L/R
- Flip - Shift+H/V
- Lossless Rotate - Ctrl+Shift+L/R
- Lossless Flip - Ctrl+Shift+H/V
- Save As - Ctrl+Shift+S
- Show/Hide Status Bar - Ctrl+Shift+B
- Switch the Tabs - Ctrl+Tab, F8, Ctrl+Shift+Tab, Shift+F8
Thank you Pierre, again!
- Toggle views - F9
- Options - F12
- Flip - Shift+H/V
Request sent---
OK, I'll add it to the list in my first post.marsh wrote:Keyboard shortcut for jpg lossless crop would be useful. It is the only toolbar button I use.
Any suggestion? Ctrl+Shift+Y? (Please check "Key Combinations" in Help first)
Current "crop" shortcuts:
Crop - Ctrl+Y
Another "lossless" shortcuts:
Rotate -90 Shift+L
Rotate 90 Shift+R
Rotate -90 lossless (jpeg) Ctrl+Shift+L
Rotate 90 lossless (jpeg) Ctrl+Shift+R
I would appreciate a HotKey regarding the Cache (Optimize / Rebuild )...
( I haven't seen something about that in "the Help" (Miscellaneous / Key Combinations ))
[Shift]+[F5] could be a good idea !? ([Shift] or [Ctrl] or [Alt], for me, that doesn't matter (but with [F5] please !)
What do you think about ?
OK, but what you want, Optimize or Rebuild?ch3n3 wrote:I would appreciate a HotKey regarding the Cache (Optimize / Rebuild )...
I think there is no Rebuild option there, just enable, disable and optimize.
I think such option (Optimize cache and maybe also Enable/disable cahce) should be also in menu, you could create new topic for that (item in menu and shortcut), I could add a shortcut to this list too, of course.
For me it's "Optimize" (the same function we already have in : "Options" / "Browser" / "Cache" -> [Optimize])
I often use this feature because when we modify pictures the thumbnails seem to "rebuilt" themselves on each folder access... The solution is to "Optimize" the Cache...
...And I would appreciated a HotKey that would facilitate this process
OK, so you want shortcut for just one option, right?
I'll add this to my request list:
Optimize Cache - Shift+O and Shift+F5
