Suggestion> Add ImageShack Hosting URL to Info Menu
ouistiti
Post by ouistiti »
Besides, except one thingy in the same Painting by Google (! not really a XnView fan…) reserved to the Gmail users only, I couldn't find out any image site in French.
- Let know that we have French-speaking users here unable to read four words in English, such an addition should be totally useless for them…
• I use too my Web site space to host the image to display in the fora.
1,77245385090552...
XnTriq wrote:
ImageShack ([url=http://reg.imageshack.us/content.php?page=developer]Introduction and Usual Requirements of the XML API[/url]) wrote:The ImageShack Developer center allows a complete integration of ImageShack's services into any website or software via the use of an XML API, is subject to the ImageShack Terms of Service, and is free to use.
Terms specific to the XML API:
  • Website or software must already be developed or have a strategic plan to be developed in the near future.
  • Website or software users must be informed that ImageShack is providing free image hosting.
Free implimentation support is offered to websites that have at least 500 unique visitors per day (users) or expect to achieve 500 users in the near future. Otherwise, the XML API is offered as is.
Request a key to gain access to this page. In your email, specify the amount of unique visiors your site gets per day and include a description of how you intend to use the ImageShack XML API.
Yes, i know that, but i don't how to develop with XML API easily :-)
nightflyer
Post by nightflyer »
If you want to try how such option works for ImageShack and Flickr, try Directory Opus 9 filemanager, which has such feature.
-=nightflyer=-
nightflyer wrote:If you want to try how such option works for ImageShack and Flickr, try Directory Opus 9 filemanager, which has such feature.
Ok, i've foudn how to do that :-) So with next release, a plugin to send a file into ImageShack will be available.
eweryboooody
Post by eweryboooody »
xnview wrote:Ok, i've foudn how to do that :-) So with next release, a plugin to send a file into ImageShack will be available.
yes! cool thang!! :D
herr_k.
Post by herr_k. »
uh,cool!
maybe,also alternatives will work with a little codetwist then...
Dreamer
Post by Dreamer »
Closed - moved to Resolved Bugs & Requests.
Dreamer
