A few Mezich-like icons
mezich
Compare icon
Post by mezich »
Some versions
First (balance) is straight metaphor of "compare". But I'm not shure that it can be clear in context of application.
And I'm not found compare function in version 0.005 (Jul 2 2008) :(
oops66
Post by oops66 »
xnview wrote:Here is the icons of Yuri:
What do you think? (It's not save as but save)[/img]
Personally, I prefer the first one for "Compare" (more intuitive).
About the Save icon: yes but without the "?". ("Save As" with "?" , Save without "?").
XnViewMP Linux X64 - Debian - X64
JohnFredC
Post by JohnFredC »
Compare and Balance are both binary concepts, but Compare is a passive activity, Balance an active activity.
Balance adjusts relationships, Compare merely views them. (That's why I used the Mezich viewing eye in my version).
Compare #1: I really dislike this one, though it has a distinctive shape and visual "granularity" (good for hand-eye coordination). The problem is the visual connotation... not so good.
IMHO Compare #2 means "Overlap" or "Merge" or (almost) "Copy" and even hints at "Resize".
Compare #4: Is that a CD or DVD disc? Or a shield? Or a trash can lid? And why is it there?
Only #3 approaches something that means Compare to me since it looks like a compare. Compare generally is between two or more different objects, rarely the same object... so the second of the two images (in the icon) should look different.
Sorry to be so unenthusiastic about these Compare alternatives. It is really hard to do properly: cross-cultural symbology and human factors visual design all at once!
John
oops66
Post by oops66 »
Yes the symbolic idea depends of each countries cultures (and sometimes of each families or persons) it's what why it is very difficult to harmonize items like that.
But I agree, n°2 likes merge, n°4 likes ?, I prefer the n°1 but the n°3 is not too bad for me too.
In this case why not n°1 or 3 with the sign "?" inside or "=?" ?
So ...?
JohnFredC
Post by JohnFredC »
#3 also looks like "Strip of images"
John
oops66
Post by oops66 »
JohnFredC wrote:#3 also looks like "Strip of images"
Yes but no with the the sign "?" inside.
mezich
Post by mezich »
too much questions in ui :)
Now I'm thinking about '=' between two images.
oops66
Post by oops66 »
Yes, why not the sign "=?" inside. :D
JohnFredC
Post by JohnFredC »
Yes, the "?" is needed with the "=" metaphor! ...otherwise it would look like "make equal"... not "Compare"
Compare is a sort of interrogative activity and could be interpreted as "are these equal?" or "how do these differ?". This would be consistent with "=?" overlaid on the two images.
I actually tried that approach when preparing my version, but the image became too visually complicated for an icon. 24x24 is too small for that many elements.
Here was another of my Mezich-like designs for Compare:
It captures the passivity of the Compare activity (looking only, not changing) and its intrinsic dichotomy, but misses XnView's version of Compare, which allows more than two images.
John
mezich
Post by mezich »
What do you think about this version of compare?
oops66
Post by oops66 »
mezich wrote:Image
Yes, for the n°2 but with "?" too above the "="...
In fact this one is not to bad too, and means for me "take a look".
So I do not know exactly now about the "Compare" icon
mezich
Post by mezich »
"take a look" is too common
With cactus---
:arrow: oops66
:) Hello !
…Personally, I prefer the first one for "Compare" (more intuitive).
About the Save icon: yes but without the "?". ("Save As" with "?" , Save without "?")…
- I fully agree for the three; about "Compare", that I use in my own large test-skin :
- The cacti (*) to show that a CRC is done, so a possible hitch can be found…
(*) In French, from a famous song, “cactus” means also hitch, snag…)
- For once I'ld not follow the John's reasoning, I guess that the pair of scales is really the most explicit¦meaningful symbol.
:mrgreen: KR
oops66
Post by oops66 »
mezich wrote:In fact this one is not to bad too, and means for me "take a look".
Yes but I mean, take a look between two or several images !
But Clo's icon is fine for me too (with the pair of scales and the "?" or "=?").
Or maybe with the "=" into the first scale, and the "?" into the second scale.
So ???
Moderator & Librarian
  • Image
ImportClipboard + NewFolder + SaveAs = sparkling* new
