Ximagic Denoiser Plugin
All non-XnView related: softwares, formats, imaging, photography...
eL_PuSHeR
Re: Ximagic Denoiser Plugin
Post by eL_PuSHeR »
Hi, Blas.
I have found what it seems a bug in the NL Means denoiser plugin behaviour. Get this back cover and use NL Means on it with the following parameters:
Spatial Sigma: 30
Learn Radius: 16
Compare Radius: 5
Enhanced mode
Then, there appears heavy pink artifacts at the bar code. Is this normal?
Also, If you disable the enhanced box, the NLM seems to do just nothing.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
brodriguez
Post by brodriguez »
Hello
eL_PuSHeR wrote:Then, there appears heavy pink artifacts at the bar code. Is this normal?
More o less, it is something that happen in older versions, but I think I solved it.
This image shows I didn't and I must work on it again. :(
The issue only happen using the enhanced version.
eL_PuSHeR wrote:Also, If you disable the enhanced box, the NLM seems to do just nothing.
If you look at the difference image in the plugin window, you'll see the noise it removes, it is up to 39 units in the 0-255 scale.
Anyway, this kind of periodic noise created by printing is difficult to remove with usual denoising algorithms.
The best way to remove it is working in the frequency domain (with FFT).
eL_PuSHeR
Post by eL_PuSHeR »
Thank you very much.
Intel i7 5960X
8 GB DDR4 (2100)
Ximagic Denoiser Changelog wrote:
  • v4.0.0 (29/Mar/2011)
    • New UI design
    • Added automatic saved previews
    • Added 64 bit support for Mac
Changelog wrote:
v 4.1.0 28-Apr-2011
  • Added smart filter support (CS3/CS4/CS5)
  • Win- Patch- Editing numeric text field doesn't update associated updown control
  • Win- Patch- Crash when closing the plug-in, using OK or Cancel, detected on several editors (PS CS5, GIMP, ...)
v 4.0.2 19-Apr-2011
  • Win- Patch- Crash when closing the plug-in, if a progress bar appears after hitting OK. (detected on PS CS3 + XP)
  • Win- Patch- Disable plug-in window when opening a child window (f.i. progress bar)
  • Win- Patch- Disable double click on title bar
  • Win- Patch- Catch plug-in errors and avoid host crash whenever possible
  • Mac- Patch- Denoiser crash when using OK with partial preview visible
v 4.0.1 11-Apr-2011
  • Win- Use XP style for UI even if the plug-in host don't use it (f.i. GIMP)
  • Win- Patch - Error in preview paint which could crash the plug-in
  • Win- Tested with new hosts Paint.NET, NiGulp, RealWorld Paint.COM, ImageN.
  • Win- Patch - Plug-ins without product version crash(f.i. Magix Photo Designer)
  • Win- Patch - Workaround for bug in Magix PhotoDesigner when used with a selection mask
  • Mac- Patch - Page scroll don't work as expected where smooth scroll is active
