XnView Shell Extension
maurizio.sedda
Re: XnView Shell Extension
Post by maurizio.sedda » Wed Feb 17, 2016 9:15 am
What has changed from the last time you had success using Xn shell extension?
I've no idea. I did not recognize immediately, but then I found that the XnView Shell menu disappeared from the explorer.
Are you sure you're using x64 version on x64 OS?
Yes. I'm using x64 OS. Installing a x86 DLL is not working. Most of my applications are x64.
Do you have any advanced security software like ZoneAlarm working which can potentially silently block your register attempts?
At the beginning I thought it was the antivirus, so first I tried to deactivate, then to remove it... without any results. I do not use any other security program.
I'm sad. :(
Peter2
Post by Peter2 » Wed Feb 17, 2016 9:44 am
Because there are no other messages about this problem it seem that it is a special problem of your PC. Have you checked the topics of "locked DLLs" and so on? Maybe there is something locked when PC is booted? One of these tool can probably help you: http://www.gibinsoft.net/gipoutils/fileutil/
XnView 2.49.2 German, Win 10
todoen
Post by todoen » Tue Mar 14, 2017 6:17 pm
Hi. Thanks for your excellent extension. i have 3.6.0 version, but i don't found installer now? downgrade? :D NOTE: In 3.6.0 imageshack don't work... :shock:
Peter2
Post by Peter2 » Tue Mar 14, 2017 6:33 pm
todoen wrote:Hi. Thanks for your excellent extension. i have 3.6.0 version, but i don't found installer now? downgrade? :D NOTE: In 3.6.0 imageshack don't work... :shock:
Where have you 3.6.0 from?
Here is 3.5.1, http://www.xnview.com/de/xnshell/ and in current XnView 2.39 there is also 3.5.1 ...
Maybe it is a part of another compilation???
Paultx
Post by Paultx » Tue Mar 14, 2017 7:39 pm
Do I need to uninstall a previous version to install a new one? TIA.
Desktop: Windows 10 Pro 64-bit • Intel Core i7 • 12 GB RAM
Laptop: Windows 10 Pro 64-bit • Intel Core i5 • 6 GB RAM
Paultx
Post by Paultx » Thu Mar 16, 2017 8:11 pm
I downloaded and installed the latest version available on the site and it's 3.6.0.
sprayer
Post by sprayer » Sat Aug 05, 2017 7:35 am
Hi, please add support webP images in preview
PhilD
Post by PhilD » Mon Nov 27, 2017 8:07 pm
Is there a Resize tool for Jpegs?
If so where is it? And if not, why ever not ?
Thanks PhilD
BretKarson
Post by BretKarson » Thu Jan 18, 2018 1:43 pm
I work with EXR files a lot, and often in need to do quick conversions to low-bit formats. Is it possible to add EXR files to the context menu of XnShell?
Post by xnview » Fri Jan 19, 2018 8:54 am
BretKarson wrote:I work with EXR files a lot, and often in need to do quick conversions to low-bit formats. Is it possible to add EXR files to the context menu of XnShell?
do you have OpenEXR.dll in Plugins folder of XnView?
dragonmoony
Post by dragonmoony » Thu Jul 19, 2018 2:44 pm
Is there a way to only specify 1 dimension so that the other one scales uniformly (instead of stretching to fit both)?
Something like scale the largest axis to x, instead of scale both to specified resolution
Post by xnview » Thu Jul 19, 2018 3:54 pm
you can enter 0 on one dimension
JuhaW
Post by JuhaW » Fri Aug 31, 2018 9:42 am
Is .exr thumbnails supposed to appear in Windows file explorer as .hdr and other image formats ?
Post by xnview » Thu Sep 06, 2018 10:48 am
XnView Shell Extension v4.0 is available
- full unicode support
BALTAGY
Post by BALTAGY » Sun Sep 09, 2018 9:19 am
Clicking on the image preview just open XnView not the image, going back to v3.60 fixed the problem
