WebP support
JOZIKus
Re: WebP support
Hi. WebP support in xnView is about to years outdated by now. I would like to petition devs to upgrade. Could You direct me how I could do that? Thank You.
Re: WebP support
what's the problem?JOZIKus wrote:Hi. WebP support in xnView is about to years outdated by now. I would like to petition devs to upgrade. Could You direct me how I could do that? Thank You.
JOZIKus
Re: WebP support
mostly the lack of ability to config other webp options rather than just the quality. and the plugin code version is v0.2.0 (I believe) instead of the current v0.4.1. Could You invest some attention and upgrade it? I Love Your product! Use it most every dayxnview wrote:what's the problem?JOZIKus wrote:Hi. WebP support in xnView is about to years outdated by now. I would like to petition devs to upgrade. Could You direct me how I could do that? Thank You.
omniplex
Re: WebP support
In addition to what others wrote: There is now a lossless WebP variant. I'm still unsure about their lossy format, but the lossless codec can create smaller pictures than PNG, and that's mildly interesting.xnview wrote:what's the problem?
Apparently XnViewShellExt(64) 3.5.0 (2012) does not yet support WebP, please support WebP when you have to update the XnView shell extension anyway.
heimaki
Re: WebP support
it seems wepb is supported now, but something is confusing when saving:
it is not obvious at all what to do if one wants to save lossless, as far as i can tell, we need to set quality to 100% to get this, everything below is lossy.
it would make much more sense to have a seperate (radio)button for lossless.
webp lossless is great, it compresses a lot better than png. but yes, it is slower, too.
omniplex
Re: WebP support
heimaki wrote:webp lossless is great, it compresses a lot better than png
Two examples, FFmpeg rgbtestsrc, a simple RGB image to spot RGB confusions, PNG: 737 bytes, VP8L (WebP lossless): 134 bytes. Something with DPX and XnView is wrong, it shows RGB as BGR, 302 KB, certainly more than 134 bytes.
Clear1x1, an image with one transparent pixel, PAM: 69 bytes, GIF: 45 bytes, PNG: 70 bytes, VP8L: 36 bytes, WebP beating all others.
Two caveats, WebP VP8L is by definition RGBA in 32bits, and an FFmpeg MD5 for another pix_format, e.g., RGB without alpha, won't match the RGBA MD5. At least PNG-fans should already know that "lossless" requires a precise definition. And, obviously, there generally is no "lossless" conversion from 48 or 64 bits per pixel to WebP; that could be a job for lossless BPG.
Back to XnView, apparently XnViewShellExt64.dll 3.5.1 (February 2015) is still up to date, and still does not support WebP, or if it supports WebP please tell me how to arrange this in a Windows 7 registry.
Mixer
- Banned
Re: WebP support
If you open XnViewShellExt64.dll in text editor there is plenty of text strings "webp", "WebP" inside, so maybe it has functions to process them, I don't know. When extension is registered, it is registered in section ContextMenuHandlers for all types of files (in HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\IXnView and HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\shellex\ContextMenuHandlers\IXnView keys of registry). I'm suspecting it decides on its own when to show itself, and probaly currently it doesn't recognize webp as type it can handle, which doesn't mean it really can't. But I don't know for sure.omniplex wrote:Back to XnView, apparently XnViewShellExt64.dll 3.5.1 (February 2015) is still up to date, and still does not support WebP, or if it supports WebP please tell me how to arrange this in a Windows 7 registry.
heimaki
Re: WebP support
just stumbled upon this:
i have a feeling, in xnview we still have an old webp lib. i compiled the newest one myself, but xnview simply crashed with that one.
omniplex
Re: WebP support
Makes sense, and that could be an ordinary bug. FWIW there's a RIFF string in the XnViewShellExt64 binary, but no VP8 for WEBPVP8 or WEBPVP8L.Mixer wrote: it doesn't recognize webp as type it can handle, which doesn't mean it really can't.
An interesting FLIF-thread, thanks for the link. XnView/Plugins/WebP.dll was apparently created in January 2015, this could be libwebp 0.4.2. The latest libwebp 0.5.0 was released in December 2015. The WIC codec 0.19 is three years old.heimaki wrote:i have a feeling, in xnview we still have an old webp lib. i compiled the newest one myself, but xnview simply crashed with that one.
UPDATE, some hours later: The XnViewMP 0.79 webp.dll (410 KB, 2016-02-19) apparently works as is also with XnView classic 2.36. The XnViewMP binary is shown as 0.77 in explorer, but it's actually 0.79 (it also contains the same libflif,dll as XnView classic 2.36).
UPDATED UPDATE: The MP 0.79 WebP.dll is unsuited for XnView 2.36 classic under Windows 2000, and 2.36 is apparently not more good enough for W2K, I'll freeze classic at 2.35 for my W2K VM.
WinnieW
Re: WebP support
I agree with you.heimaki wrote:it seems wepb is supported now, but something is confusing when saving:
@Author of XnView
I'd really like to see a dedicted switch to toggle between lossless und lossy mode.
BTW libwebp 0.5.1 has been released a few hours ago.
Some notable improvements: Bug fixes and faster lossless encoding
tor11
Re: WebP support
I have XnView 2.54. I have checked "Display all image file types" in Options, but I still cannot open webp image files, why?
VTT
Re: WebP support
I was going to post about the lack of WebP support as well, but it turned out that all I had to do was to download Extended installer and mark WebP plugin for installation.
tor11
Re: WebP support
Thanks for that reply. I have portable version, but it was really easy, just downloaded .dll from http://www.xnview.com/old/en/plugins.html and copied it to Plugins dir. Thanks
DOS386
Re: WebP support
http://entropymine.com/imageworsener I've now found Image Worsener that can decode WEBP's natively without problems and without plugins ... so I do no longer need WEBP support in NC/XN. Additionally, Image Worsener provides better zooming (16 bpps and without the infamous Gamma-BUG) and palettizing. It can't rotate images, though.
Some early WEBP's do no longer decode: http://newsgroup.xnview.com/viewtopic.php?t=33101
WinnieW
Re: WebP support
Maybe some early pictures from before webp format was finalized or some pictures from an experimental branch leaked in public?DOS386 wrote:Some early WEBP's do no longer decode: http://newsgroup.xnview.com/viewtopic.php?t=33101
