"Use delayed high quality preview for pictures larger than (pixel)"?Danny wrote:It only applies to the preview area of the browser.helmut wrote:And the wording needs to be improved and made clearer. E.g. I don't understand what the "(browser only)" means.
Some possible wordings:
1 - "Use delayed smoothening for pictures larger than (pixel)"
or
2 - "Use delayed high quality for pictures larger than (pixel)"
or
3 - "Use delay before high quality view for pictures larger than (pixel)"
"Use 2-step high quality preview for pictures larger than (pixel)"?
RC5: Preview still built in two steps
marsh
Dreamer
I vote for this:
or this:"Use 2-step high quality preview for pictures larger than (pixel)"
...because it's clear, term "high quality" is used also in Slide Show, High Zoom Quality... so I think "high quality" should be used here too."Use delay before high quality view for pictures larger than (pixel)"
My current favourites are a mixture:
"Use delayed high quality view for pictures larger than (pixel)"
or
What do English native speakers suggest?
If this setting affects the preview in browser, only, I think this should be moved to category "Browser > Preview".
or
ckit
Out of those two I like...helmut wrote:My current favourites are a mixture:
or
because we already have "Use high quality" in Browser -> Preview and this would match it in wording.
I agree to the second issue.
Olive
Hacker
marsh
OT: This speed comparison might be interesting between the 2 fullscreen modes.
It seems to show a speed difference only at Low Quality.
Quick-Slide-Show Delay "0" 200MB of 500k jpgs
Fullscreen 70seconds.
Preview Fullscreen 70 seconds.
LQ Preview Fullscreen 40 seconds.
Delayed HQ Preview Fullscreen 2048pixels 65 seconds.
Delayed HQ Preview Fullscreen 512pixels 45 seconds.
Lesmo16
Pierre, please let it affect for preview too.xnview wrote:Perhaps it's problem that this setting affect preview too????Olive wrote:It actually affects preview and fullscreen-lite, not fullscreen proper. So yes, either move it to browser>preview or leave it in fullscreen but add "(also affects preview)" at the end of the string.
BTW: I support Olive's suggestion: "(also affects preview)".
Everyone who believes in telekinesis, raise my hand!
No it's the size in width or height in pixels. So 2048 means >= 2048 x 2048helmut wrote:Good question. I thought it would be width or height. If this is really the case, the wording for the option has to be changed.Hacker wrote:BTW: What is the value you enter there? The image size in pixels? So the default 2048 means images larger than 64*32?
Lesmo16
Why using something from inside the image?xnview wrote:No it's the size in width or height in pixels. So 2048 means >= 2048 x 2048helmut wrote:Good question. I thought it would be width or height. If this is really the case, the wording for the option has to be changed.Hacker wrote:BTW: What is the value you enter there? The image size in pixels? So the default 2048 means images larger than 64*32?
Why not using file size in bytes?
Everybody knows the file size from his filemanager without looking into the file.
This also doesn't care about image ratio.
The speed of the smoothening (high quality) depends on the number of pixels, I guess this is the reason why Pierre uses pixels as units.Lesmo16 wrote:Why using something from inside the image?
Very strongly compressed files (e.g. JPG) could have a small file size but a large number of pixels (dimension). So file size would not be fully correct. But even Pierre's current approach has a flaw, what happens if a file is 3000 pixel wide but only 10 pixel high?
Not sure what a really good solution is. Currently I'd prefer file size to "pixel" (which is actually height / width).
Olivier_G
Maybe we should use what Hacker mentioned previously: the number of pixels (as the surface area: width x height) ?
=> "Use 2-step high quality preview for pictures larger than [X] Mega-Pixels"
Most people know what a "Mega-Pixel" is (thanks to digital cameras), it does represent exactly the complexity of the operation... and you can use a pretty single-digit default number.
Olivier
Olivier
JohnFredC
