ATM, I'm not 100% sure: The current star ratings are not just stars, they have labels. So one star might be good in a star only rating. But in XnView's current rating one star is "Poor". Due to the lack of other ratings people might have used the rating "Poor" for outtakes for example.XnTriq wrote:... I don't think this would break the existing system or have an adverse effect on compatibility with other apllications.
Terminology of rating system
Re: Terminology of rating system
- Forum Librarian
XnView MP uses xmp:Label for storing color labels.helmut wrote:ATM, I'm not 100% sure: The current star ratings are not just stars, they have labels. So one star might be good in a star only rating. But in XnView's current rating one star is "Poor". Due to the lack of other ratings people might have used the rating "Poor" for outtakes for example.
MP's star ratings (0 and 1 through 5) are stored in xmp:Rating. As far as I know, -1 is still available to be used as rejection flag.Adobe ([url=http://www.adobe.com/content/dam/Adobe/en/devnet/xmp/pdfs/XMPSpecificationPart1.pdf]XMP Specification Part 1[/url] ) wrote:
- xmp:Label
- A word or short phrase that identifies a resource as a member of a user-defined collection.
NOTE: One anticipated usage is to organize resources in a file browser.
To ensure compatibility with Microsoft's applications like Windows (Live) Photo Gallery, MicrosoftPhoto:Rating is also added.Adobe ([url=http://www.adobe.com/content/dam/Adobe/en/devnet/xmp/pdfs/XMPSpecificationPart1.pdf]XMP Specification Part 1[/url]) wrote:
- xmp:Rating
- A user-assigned rating for this file. The value shall be -1 or in the range [0..5], where -1 indicates “rejected” and 0 indicates “unrated”.
If xmp:Rating is not present, a value of 0 may be assumed.
NOTE: Anticipated usage is for a typical “star rating” UI, with the addition of a notion of rejection.
ExifTool (Tag Names » [url=http://www.sno.phy.queensu.ca/~phil/exiftool/TagNames/Microsoft.html]Microsoft XMP Tags[/url]) wrote:
- RatingPercent
- called Rating by the spec. XMP-xmp:Rating values of 1,2,3,4 and 5 stars correspond to RatingPercent values of 1,25,50,75 and 99 respectively
- Excellent
- <xmp:Rating>5</xmp:Rating>
<MicrosoftPhoto:Rating>99</MicrosoftPhoto:Rating>
- <xmp:Rating>4</xmp:Rating>
<MicrosoftPhoto:Rating>75</MicrosoftPhoto:Rating>
- <xmp:Rating>3</xmp:Rating>
<MicrosoftPhoto:Rating>50</MicrosoftPhoto:Rating>
- <xmp:Rating>2</xmp:Rating>
<MicrosoftPhoto:Rating>25</MicrosoftPhoto:Rating>
- <xmp:Rating>1</xmp:Rating>
<MicrosoftPhoto:Rating>1</MicrosoftPhoto:Rating>
- <xmp:Rating>0</xmp:Rating>
<MicrosoftPhoto:Rating>0</MicrosoftPhoto:Rating>
- Important
- <xmp:Label>Red</xmp:Label>
- <xmp:Label>Yellow</xmp:Label>
- <xmp:Label>Green</xmp:Label>
- <xmp:Label>Blue</xmp:Label>
- <xmp:Label>Purple</xmp:Label>
- <xmp:Label>None</xmp:Label>
Cutomization of the terms for the star ratings is also possible, but has to be done by editing xnview.ini:
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=134675#p134675]Customise meaning of stars and colours[/url]) wrote:The wording changed accordingly in the Categories Filter panel but not in the View » Rating & Colour label menuCode: Select all
[Browser] ratingLabel=Unrated, One, Two, Three, Four, Five
