List of missing features (compared to XnView Classic)
Moderators: XnTriq, xnview
BloodyRain2k
Re: List of missing features (compared to XnView Classic)
Post by BloodyRain2k » Sat Mar 01, 2014 12:13 am
confona wrote:IS MP supposed to be an improvement over Classic?
I can't extract gifs or tile pictures for comparison in MP. So it's back to Classic for me.
Removing features that attracted users is not the way to go about improving on an app.
Also, if you create an app that is highly customizable with many different settings, please add an "export" current settings feature, so we can save those preferred setting in case we need to reinstall later.
Yeah I'm still using classic too, mainly because I really don't want to lose my categorizations and I'm unsure how stable the database is already but mostly do I miss the ability to view images side by side.
And yes the setting exporting is a nice idea, I'd like that too.
Win7 HP x64 - XnViewMP x64
JohnFredC
Post by JohnFredC » Sun Mar 02, 2014 9:33 pm
confona wrote:Removing features that attracted users is not the way to go about improving on an app.
MP is in beta. Features haven't been "removed", they just haven't been added yet.
... and in many respects MP IS better than Classic already. You should explore it a bit more.
John
JohnFredC
Post by JohnFredC » Sun Mar 02, 2014 9:37 pm
BloodyRain2k wrote:
confona wrote: I miss the ability to view images side by side.
In the MP browser...
- Select a couple of images.
- Tools->Compare
Though it has a long way to go 'til a full implementation of compare, nevertheless the MP compare mode is much improved over the one in Classic XnView.
John
BloodyRain2k
Post by BloodyRain2k » Sun Mar 02, 2014 10:05 pm
- Tools->Compare
I'm aware of the Compare function (shift+c) but if that'd fill the spot I'd be less annoying about the unimplemented side by side viewing ^^
Also when I just tried it and selected 3 images for which it didn't have thumbs yet and pressed shift+c to do the compare it simply CTD'ed, I know, beta and all, just saying.
I'll still be checking out XMP every now and then to see if I can finally replace classic, I just cleaned up my database and removed all thumbs from images that I haven't categorized (1600mb -> 125mb) by removing all the thumbs with SQLiteSpy which went over it pretty fast but then classic took a few hours to fix up whatever I missed, I was also wondering why the file size didn't even change. In the end all this did nothing though... still crawling around : /
ikletti
Post by ikletti » Wed Mar 12, 2014 7:56 am
- Tools->Compare
I second the vote for a "tile view". The compare function may be a great feature but (IMHO) the ability to tile some images already opened in tabs is a necessary feature. In addition, the compare view currently does not allow for viewing more than four pictures at a time (tested on Ver. 0.64) even if more pictures are selected.
JohnFredC
Post by JohnFredC » Wed Mar 12, 2014 11:38 am
ikletti wrote: the compare view currently does not allow for viewing more than four pictures at a time (tested on Ver. 0.64) even if more pictures are selected.
I understand.
As a work-around and for large feature comparison, in the browser one can hide all but the thumb panel, maximize the MP window, then set the thumb slider to a grid size that emulates the comparison tool.
Three thumbs across, for instance.
That could give you a scrollable 3 x n grid to work with.
As a matter of policy one can set the cached thumb size much larger than the size one customarily displays in the browser so that more detail is retained in the cached thumb for use under just these sorts of circumstances.
If you need to zoom then navigate the images, though, obviously this approach won't help.
John
Silversleeves
Post by Silversleeves » Tue Apr 01, 2014 10:13 am
By no means. MP is a "parallel build," for want of a better phrase: the same application on the three "platforms" of Mac OS X, the numerous flavours of Linux, and Windows. Years ago, Pierre wrote a Linux version of XnView; instead of doing the same thing again, he's opted to use a Classic 'foundation' of a more-recent vintage and build at the same pace across platforms, leaving no one out. Yes, there are some things in the Windows builds of MP that are improvements, and a lot of things missing, but if you imagine you're building three cars at once, each from a kit and trying to do all three at the same pace (and the crowd is yelling "Add this! Improve that?" or asking "Why doesn't my W do XYZ?"), you get an idea of the task Pierre has taken on.
BZT
berniz95
Post by berniz95 » Fri Apr 18, 2014 7:47 pm
ikletti wrote:From this post dating back to March 2012:
xnview wrote:
helmut wrote: • Acquire from Scanner or Camera
You have it already :)
I guess it should be possible to acquire from a scanner in XnviewMP. But running Version 0.61 on Kubuntu 12.04 (LTS) I can not find any menu entry or button even remotely resembling "scan" or "acquire". I even switched between the UI language from English to French and German and waded through the menus just to make sure.
My scanner is working fine using xsane. Could somebody shed a light on this, please?
Edit:
I now have tried XnView MP Version 0.61 on a Windows 7 (64 Bit) system where I see a menu entry for scanning in the "File" menu. So I went back to Linux, and just to make sure, uninstalled XnView MP and reinstalled it. Still no menu entry for scanning. Is this related to the different backends (TWAIN vs. SANE) and how can I fix this (no programming skills, else I'd offer my help there)?
I fully agree with this post - no way I can scan using XnView MP under Ubuntu. Is there anything new on that subject ?
Cheers
berniz95
Post by berniz95 » Fri Apr 18, 2014 7:54 pm
helmut wrote:<Moderator's note: This topic has been split from another topic>
Again, thanks for your list of additional features and differences between XnView Classic/Windows and XnView MP, budz45!
I'd be very interested to see a list of features that are available in XnView Windows/Standard which are still missing in the current version of XnView MP. I guess this list is important for those users that think about switching from XnView (Classic) to XnView MP. Are there (m)any features missing?
___
XnView MP 0.53 beta: List of missing features (compared to XnView Classic): Last update: 20 Feb 2013
• Red Eye Correction
• Slide show
• Print
• File Associations
• Add Text to image
• Add Watermark
• Paint
• Effects
• Open Page number
• Contact Sheet
• Create Web Page
• Create Multi-page file
• Create Strip of Images
• Metadata support (? status not 100% clear)
• Sequence convert (? see discussion below)
• View in Hex mode (? see discussion below)
Considering my own use of XnView, I would add or precise : intelligently designed batch file renaming, sequence convert, and Acquire from Scanner or Camera (which seems to be available on Windows but not Linux).
Cheers
m.Th.
Post by m.Th. » Sat Apr 19, 2014 5:35 am
___
• Slide show
• Print
• File Associations
• Add Text to image
• Add Watermark
• Paint
• Effects
• Open Page number
• Contact Sheet
• Create Web Page
Cheers
Batch file renaming on XnView MP has all the features from XnView and it adds some new ones like Preview.
m. Th.
The Ascetic Experience - The best photos and texts from Holy Mountain (Athos)
- Dark Themed XnViewMP 0.90 64bit & XnView 2.00 x64 on Win7 x64 -
mrwul
Post by mrwul » Sat Jun 28, 2014 7:04 am
Pls note that the link in:
"<Moderator's note: This topic has been split from another topic>" (p.1)
is not working, website not found.
Just a tip.
TD
Post by TD » Fri Jul 04, 2014 4:19 pm
How about "companion files"?
Regards,
ikletti
Post by ikletti » Fri Jul 18, 2014 7:26 am
Relating to:
Edit:
Cheers
I just found this question & answer in another thread:
CollinTheGeek wrote:I've just installed XnViewMP v0.68 on my computer (Fedora 20) so I could scan old pictures and embed data in the metadata But there is no scan button on my toolbar. I can't find any help online please help me.
Thank you!
CollinTheGeek
XnTriq wrote:This feature has yet to be implemented in the Linux edition.
oops66
Post by oops66 » Sun Jul 20, 2014 8:54 pm
• Slide show
Particularly missing for me, with the ability to create some .sld, .scr, .exe, cd/dvd, .avi/mpg4 video files slideshow with transitions and songs.
XnViewMP 0.82 Linux X64 - Ubuntu 16.04 LTS - X64
bio67
Post by bio67 » Sun Nov 09, 2014 4:31 pm
I'm missing the "open all" command in the context menu when have chosen several thumbnails
