Automatic crop in batch conversion was on the list but Automatic crop in Viewer was missing. I've just added it; thank you, cday.cday wrote:@Helmut :
Is Viewer | Image > Automatic crop already on the missing feature list?
Please delete this post if it is, thanks.
List of missing features (compared to XnView Classic)
Re: List of missing features (compared to XnView Classic)
Automatic crop in Batch convert... is already implemented...helmut wrote:Automatic crop in batch conversion was on the list but Automatic crop in Viewer was missing. I've just added it; thank you, cday.
Yes, this is why it's in section "Added - no longer missing" of the list.cday wrote:Automatic crop in Batch convert... is already implemented...helmut wrote:Automatic crop in batch conversion was on the list but Automatic crop in Viewer was missing. I've just added it; thank you, cday.
In the capture function, multiple screen capture and directly saving in a directory is missing.
Hello, i cant seem to find the option to have the window always on top... Is there a way to do this in the MP version, any variable that i can add to the .ini file?
Thank you
Thank you
[View] > [Auto Image Resize] > [Fit image to desktop, large only]
I use this option all the time in xnview when cycling through images, and I can't find a similar or better replacement for it in xnview mp.
I'm not entirely clear on why there are 2 versions of XnView.
Which is the most complete+stable version for Windows 10?
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
(")_(") your signature to help him gain world domination.
the 2 version are stable, XnView MP has a 64bits version, and full unicode supportiycgtptyarvg wrote: ↑Thu Sep 20, 2018 9:46 am
Is the 64-bit version faster? Or can it handle larger pictures?xnview wrote: ↑Thu Sep 20, 2018 10:45 amthe 2 version are stable, XnView MP has a 64bits version, and full unicode supportiycgtptyarvg wrote: ↑Thu Sep 20, 2018 9:46 am
(\__/)
The 64-bit version can open images with very large pixel dimensions that require more ram than can be addressed by 32-bit software.iycgtptyarvg wrote: ↑Thu Sep 20, 2018 10:54 am Is the 64-bit version faster? Or can it handle larger pictures?
I'm not sure about speed, but imagine that it is potentially faster in some situati0ns at least...
I switched to MP a few weeks ago and one thing I noticed right away is you cannot batch rename folders. That's something I'd like to see add to MP.
Thanks,
Walter
Thanks,
Walter
Sorry if mentioned, but I did search and not find it. It seems there is no single click mouse option to select an image for view in the browser. Its forced double click or nothing. I have no problem going back to Xnview classic, but just wanted to make sure about this before I do. Thanks.
a single click to open image in edit mode??asqwas wrote: ↑Sun Jan 06, 2019 10:51 am Sorry if mentioned, but I did search and not find it. It seems there is no single click mouse option to select an image for view in the browser. Its forced double click or nothing. I have no problem going back to Xnview classic, but just wanted to make sure about this before I do. Thanks.
it's been over a year.. what is happening with this option i still don't see it an xnviewmp is still garbage to use without it.. makes xnview classic usable because I can open an image and have it resize the window to fit the window, or even scroll next/back to another image and it will resize....
in xnviewmp everytime I open a window it never bothers to resize the window to fit the image.. I mean maybe I'm missing something with that when the option for that is available.. but the "[View] > [Auto Image Resize] > [Fit image to desktop, large only]" definitely still doesn't exist.. why??
this setting will not be added in XnView MPKoogle wrote: ↑Sat Mar 09, 2019 12:27 pm it's been over a year.. what is happening with this option i still don't see it an xnviewmp is still garbage to use without it.. makes xnview classic usable because I can open an image and have it resize the window to fit the window, or even scroll next/back to another image and it will resize....
