Browser view: Remove panes' interior bevel edges...
ghost zero
Re: Browser view: Remove panes' interior bevel edges...
Post by ghost zero »
can this be fixed in the next version?
ghost zero wrote:can this be fixed in the next version?
it's fixed in 2.24
ghost zero
thanks!
ghost zero
the bevels are gone in 2.24. but i notice there is still the 1 px outline inside the panes--which is kind of like a 1 px bevel. can that be removed, too?
ghost zero wrote:the bevels are gone in 2.24. but i notice there is still the 1 px outline inside the panes--which is kind of like a 1 px bevel. can that be removed, too?
screenshot?
ghost zero
screenshots with 2x zoom. in the second screenshot, i filled the outlines with color to highlight them. my interface is customized dark, but with the default white interface they look like dark outlines for each pane.
these outlines surround the interior of each pane--like a thin bevel. can they be removed?
ghost zero
can this be done in the next version?
ghost zero
i just upgraded from 2.32 to 2.35 and i noticed the improvements mentioned in this topic has been undone. why?! please restore the improvements to remove the bevel edges in the panes, or give us an option!
ghost zero
can this be improved in the next version?
ghost zero
after checking the changelog for 2.34, it turns out this change was made intentionally after a different user complained of black contours...
http://newsgroup.xnview.com/viewtopic.php?f=39&t=31554
which was actually something i had already pointed out, but it was never addressed...
http://newsgroup.xnview.com/viewtopic.p ... 15#p122334
the proper way to fix this is to remove both the bevel edges AND black contours, to give us a truly flat minimal look--which is what i have been requesting.
i really don't like the current bringing back of the bevel edges, especially since it looks bad [like visual junk] against a black theme background, as seen in my original post...
http://newsgroup.xnview.com/viewtopic.php?f=34&t=28032
please fix or at least give us a setting to customize.
ghost zero
gosh darn it, i want this option to achieve a cleaner modern look and to get some extra screen space! can you at least give us an option to remove those ugly bevel edges around the panes? we're not on Windows 98 anymore!
