@XnView: I think you'd need to establish an OpenGL / DirectX viewing mode, loading the image as a texture on a rectangular 3d pane. Smootoh and fast zooming / panning would be as easy as resizing the pane, the graphics card would take care of the rest.
OpenGL is well documented, it should be fairly easy for a coding master like you to pull it off. It might not be an issue for most XnView users, but as others pointed out it prolly keeps many potential users away.
About the 1-developer situation: considered going open source? Or making a plug-in structure, so that a 3rd party could develop a viewer plugin?
Please don't get me wrong, I appreciate every bit of XnView and your work. But the speed issue is the one major problem many people have with it.
Speed of High quality zoom, more HQ zoom options?
LMan
Re: Speed of High quality zoom, more HQ zoom options?
Do you have tried the xnViewMP project?LMan wrote:@XnView: I think you'd need to establish an OpenGL / DirectX viewing mode, loading the image as a texture on a rectangular 3d pane. Smootoh and fast zooming / panning would be as easy as resizing the pane, the graphics card would take care of the rest.
LMan
I will, right now. Hang on.
Tried it after fixing the "side-by-side" bug in Win 7 as suggested in this thread: http://newsgroup.xnview.com/viewtopic.p ... 5&start=15
Zooming is super fast now. Page flipping works well, too!
Pre-loading more than one image might still be a good idea for going through files on a net-drive, just to compensate for low bandwidth.
Great work, looking forward to it!
