ThanksXnTriq wrote:Freeware for analyzing clipboard content:
Bug: Copy image to clipboard doesn't work anymore ...
Re: Bug: Copy image to clipboard doesn't work anymore ...
- Forum Librarian
Yes, Pierre, I know. I should've mentioned that I posted these tools for users who'd like to help out and do tests.xnview wrote:ThanksXnTriq wrote:Freeware for analyzing clipboard content:the problem is that there is no standard way to copy in clipboard a 32bits pictures
It seems that you've already found a solution, so I'm looking forward to the next release.
- Forum Librarian
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=121010#p121010]Bug: Copy image to clipboard doesn't work anymore ...[/url]) wrote:ok, so it seems that photoshop doesn't like premultiplied componenti'll add an option to use the old method...
Is the following information correct, Pierre?xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=122200#p122200]XnView 2.24[/url]) wrote:2.23/24 Changelog
Added:
* clipboard old method - http://newsgroup.xnview.com/viewtopic.php?f=36&t=30390
Add in [Start] section, ClipboardNewMethod=0
XnView Wiki (UI-less Settings » [url=http://www.xnview.com/wiki/index.php/UI-less_Settings#Start]Start[/url]) wrote:
- ClipboardNewMethod
- When disabled, XnView will copy alpha channel transparency (32-bit RGBA) as non-premultiplied/unassociated/straight (vs. premultiplied/associated) component (see Transparency – Straight vs. premultiplied alpha)
Value: Boolean (1/0), enabled by default
Added in v2.24
2blackbar
Soooo, i need to use old clipboard method, why this setting is not even in actual settings UI ? Why its hidden, photoshop is pretty popular dont you think ?
I have this problem and its very irritating, previous non MP version had this issue as well but i could just remove alpha and it worked, here it just doesnt work no matter what, Come on , dont break the program like this.At least add options to solve it in actual UI, i have to find and edit xnview ini file, what the hell ?
I dont even have ini file in mp folder...
It reminds me why i always go back to regular xnview... and i only like to use mp cause curves are few clicks closer than in old one
Why the hell do you even need workarounds for it, just make sure it works with photoshop, doesnt matter if it has alpha or not, cause at the moment it does not work at all...
- Forum Librarian
The Open Config Files Location button in Tools → Settings → Integration → Paths → XnView Settings opens the folder where xnview.ini is saved in an Explorer window. Please make sure to quit XnView before you edit the INI file.
