File->Export always disabled in 0.81 (Win x64)
foxyshadis
Post by foxyshadis »
When I upgraded from 0.79 to 0.81, the Export... option in the File menu in view/edit mode is now stubbornly always greyed out. No matter what I do, I can't get Export back, and since I used to use it constantly, I miss it terribly. Any idea why or how to fix it?
Re: File->Export always disabled in 0.81 (Win x64)
:? I assume the keyboard shortcut (Ctrl+Alt+S) doesn't work either?
Possibly related: File export does not work after image joining - V0.79
foxyshadis
Ah, it looks like it only occurs when I Import Clipboard, which is something I use all the time for screenshots, so it does seem to be the same bug. With regular open, it's always available.
I'm using 0.82 beta 3 now with the same result.
Confirmed for the following commands:
  • File » TWAIN scan...
  • Edit » Import clipboard
  • Create » Web capture...
  • Create » Join images...
From what I can see Exporting works in XnView MP v0.84.
:arrow: Closed (Please post here in case you still experience this problem.)
