When new file is opened, several older files appear [Fixed]
Moderator: XnTriq
Re: When a new file is opened, several older files appear to
Post by xnview » Mon Oct 17, 2016 12:15 pm
yanpol wrote:By double clicking the picture file, inside its windows explorer folder.
do you have always this issue with 0.83?
HanVroon
Post by HanVroon » Thu Oct 20, 2016 4:44 pm
Funny bug :D
I was reading this and tried myself with 0.83, there is even a shorter reproduce procedure I think:
1- Open an image from the Browser.
2- Close XnViewMP (assuming Save session in On)
3- Open XnViewMP again, the image opened before shows up.
4- Now open an image from Windows explorer (assuming the file type is assosiated with XnViewMP).
So don't open an image from within the Browser of XnViewMP because then it works like expected!!
5- The image double clicked in Windows explorer shows up, and indeed the image opened before from the saved session is opened a second time.
But, the funny thing is, in my case also a second Browser tab is opened. I never knew how to do that :D
yanpol
Post by yanpol » Mon Oct 24, 2016 4:04 pm
I just installed 0.83 and tried. Unfortunateley, it's the same situation.
HanVroon
Post by HanVroon » Tue Oct 25, 2016 7:24 am
I think Pierre found the problem and it will be fixed in the next release.
I receivend an informal beta last week to test.
Post by helmut » Mon Dec 05, 2016 8:45 pm
Right, HanVroon, this problem is supposed to be fixed in XnView MP 0.84 beta 1. Could you please try and confirm the bug fix, yanpol?
yanpol
Post by yanpol » Tue Dec 06, 2016 3:14 pm
I just tried 0.84 beta and yes, the problem is gone. Excellent work!
Post by helmut » Tue Dec 06, 2016 4:16 pm
yanpol wrote:I just tried 0.84 beta and yes, the problem is gone. Excellent work!
Good. Thank you for checkinig and your feedback, yanpool! :)
