0.84: Category filter: Deselecting doesn't deselect children
Moderators: XnTriq, xnview, Dreamer
Re: 0.84: Category filter: Deselecting doesn't deselect chil
Post by helmut » Fri Feb 17, 2017 9:40 am
xnview wrote:but it's already like that
No, it's not like that. When selecting with Ctrl + Mouse click, the unexpanded children will be also selected. See my steps in the original post.
Post by xnview » Fri Feb 17, 2017 10:08 am
yes but CTRL is used to select all children (same as setting>Metadata>auto apply parent keywords
So instead of CTRL what can i use?
Post by helmut » Fri Feb 17, 2017 10:36 am
Ctrl is for multi-selection and must not be used for selecting all children. The selection of children is discussed in the suggestion that m.Th. posted: http://newsgroup.xnview.com/viewtopic.php?f=60&t=34875
Post by xnview » Fri Feb 17, 2017 1:26 pm
helmut wrote:Ctrl is for multi-selection and must not be used for selecting all children. The selection of children is discussed in the suggestion that m.Th. posted: http://newsgroup.xnview.com/viewtopic.php?f=60&t=34875
Sorry my fault, i have not correctly read your first post :(
Post by xnview » Fri Feb 17, 2017 1:31 pm
O.k., thank you, I can also reproduce the problem. Issue 1112 is fixed in next version.
Post by xnview » Thu Mar 16, 2017 9:00 am
This problem is supposed to be fixed in XnView MP 0.85 beta 1. Please check and confirm the bug fix here.
vertigo
Post by vertigo » Thu Mar 16, 2017 10:14 am
Fixed, but when selecting a category with children the children aren't selected at all now...That's fine as long as that's how it's supposed to work, and I think it makes sense, but I haven't used categories, so I'm not sure. But my understanding is that before they were selected, which is why when they didn't unselect it was a problem, so it seems the overall behavior changed.
Post by helmut » Thu Mar 16, 2017 8:56 pm
Thank you for checking, vertigo. Selection of children is discussed in seperate topic, see http://newsgroup.xnview.com/viewtopic.php?t=34875
vertigo
Post by vertigo » Thu Mar 16, 2017 9:51 pm
Yeah, I was part of that conversation, just wasn't sure if a final decision had been made on it and if so if that was implemented here. Just wanted to point out the apparent change in behavior with the fix to make sure it's working as intended.
