Two different PC's, both running fully updated Win Pro 64.
XnConvert Version 1.85.1
XnView Version 2.49.4
Ghostscript Version 9.53.3
Will not convert a pdf. Returns xx.pdf 0x0x0 : not a picture error. Regardless of what I try to convert it to.
Actions taken: full reinstall of all three software, ticked the "ignore read errors", and tested multiple pdf files.
Please advise.
Thank you,
J
Re: xx.pdf 0x0x0 : not a picture
No please try XnConvert 1.90?JCMSBA wrote: Thu Dec 17, 2020 2:34 pm Two different PC's, both running fully updated Win Pro 64.
JCMSBA
@xnview
1.9 worked!
Thank you very much!
1.9 worked!
wfa
Good for you.
Can you list the complete specs
32/64bit
All versions numbers
Does the Environment variables path includes a path to gs?
32/64bit
JCMSBA
I uninstalled XnConvert, XnView, & Ghostscript.
Then installed XnConvert 64 bit, installed XnView, finally installed Ghostscript.
Result, worked.
Result, worked.
