convert sfw files to jpeg
norman jr
Re: convert sfw files to jpeg
Post by norman jr » Mon Jul 24, 2017 3:35 pm
Hey Guys:
E is my cd/dvd drive. As t0 the sfw file I will have to figure out how to convert it to a zip file. Never done that. I do have 7-zip on my computer.
Norman
Moderator & Librarian
Post by XnTriq » Mon Jul 24, 2017 3:45 pm
norman jr wrote:E is my cd/dvd drive. As t0 the sfw file I will have to figure out how to convert it to a zip file. Never done that. I do have 7-zip on my computer.
Hi again, Norman. You don't have to send a sample. The mystery is solved. XnConvert throws a “create error” because it can't write to your CD (read only). You have to enter a destination on your hard disk as the output folder.
norman jr
Post by norman jr » Mon Jul 24, 2017 7:11 pm
Many Thanks for all the help. Through you guys I found out what I was doing wrong. I was directing the converts to the wrong drive. It should have been my C drive..
Norman
norman jr
Post by norman jr » Mon Jul 24, 2017 11:36 pm
Many Thanks Guys. With your help I found the cause......I've been saving to my cd/dvd drive instead of my hard disk drive. Problem solved. Again.....Many Thanks.
Norman
Post by XnTriq » Tue Jul 25, 2017 1:30 am
Great news! Thanks for reporting back, Norman :-D
