Xcf files of Gimp 2.10 cannot be displayed
Re: Xcf files of Gimp 2.10 cannot be displayed
ok, thanks, floating pixels is not supported, i'll fix it
Akovia
Post by Akovia »
Still crashing in 0.93.1 with the same files I uploaded earlier.
Would it be possible to have a setting to turn off xcf support so I could use the program?
Arch Linux
XnView MP
Akovia wrote: Sun Mar 10, 2019 3:23 am Still crashing in 0.93.1 with the same files I uploaded earlier.
really? I have no more crash on windows
the files are no more available
you can add xcf in excluded extensions
Akovia
Post by Akovia »
xnview wrote: Mon Mar 11, 2019 3:07 pm
I'm on Arch Linux if that makes a difference.
They are still on my gdrive so I guess they must expire? I made a new share link so let me know if this doesn't work.
https://drive.google.com/file/d/1mDk2Lu ... sp=sharing
Akovia wrote: Sun Mar 10, 2019 3:23 am Would it be possible to have a setting to turn off xcf support so I could use the program?
I tried unchecking xcf from the included list before, and now added it to the excluded list as you suggested but it still crashes every time it sees an xcf.
I'm really at wits end. I've been using gimp and xnview side by side for a decade but now can't use it at all. I already can't use gimp while xnview is open and I need to copy and paste inside gimp. Now with this I can't even browse my files since my xcf files are among my finished images.
Please help.
Arch Linux
XnView MP
no, add xcf in exclude
Akovia
Post by Akovia »
xnview wrote: Tue Mar 12, 2019 8:30 am no, add xcf in exclude
Isn't that what my screenshot shows?
htm html mht mhtml xml xhtml eml nws url svg svgz tbn xcf
Arch Linux
XnView MP
you need to uncheck 'Visible' for exclude
Akovia
Post by Akovia »
OK, I guess I'm really missing something.
Here's a 40 second video of my settings and what happens when opening a folder with the xcf files I linked before.
Arch Linux
XnView MP
sorry you need to check 'Exclude' with xcf, remove xcf from 'Include', and disable 'show as thumbnail' for folder
Akovia
Post by Akovia »
xnview wrote: Wed Mar 13, 2019 8:48 am check 'Exclude' with xcf,
Does this mean check the Visible column?
I tried both ways and neither seem to work. Even tried unchecking "Show in Preview"
Can you post a screenshot of the settings I need?
https://i.imgur.com/ZLaBmiR.png
 CHECK : <5 Centimeters per Second - Poster.xcf>
LOAD BITMAP </run/media/akovia/Kodi-NAS/Media/Anime/Record of Lodoss War/tmp/xnview_crash/5 Centimeters per Second - Poster.xcf>
corrupted double-linked list
Aborted (core dumped
Arch Linux
XnView MP
you can re-download the package, there was an error in the build for xcf
Akovia
Post by Akovia »
xnview wrote: Wed Mar 13, 2019 2:12 pm you can re-download the package, there was an error in the build for xcf
Thanks!!
Arch Linux
XnView MP
Akovia
Post by Akovia »
Back again :\
It seems that thumbnails do not show for gimp's 32 Bit Floating Point Images. I just get a grey square.
I've attached a sample.
Bastard - Banner-TEST.xcf.zip
(1.04 MiB) Downloaded 39 times
Arch Linux
XnView MP
yes currently floating pixel is not supported
