PNG filesize
Re: PNG filesize
XnTriq wrote: Tue Apr 12, 2022 2:30 pm Files saved/exported with compression level 9 (highest) are supposed to be smaller than those saved/exported with compression level 1 (lowest), n'est-ce pas?
right should be, but it's libpng :)
Moderator & Librarian
Re: PNG filesize
xnview wrote: Wed Apr 13, 2022 3:01 pmright should be, but it's libpng :)
OK, you're right. I found another program which uses libpng. Exact same file sizes.
