"Never ask again" option after changes
Hakim Antoine Said
Re: "Never ask again" option after changes
Post by Hakim Antoine Said »
For Me And i Think For Every1
it´s Better...
Save - Don´t Save - Cancel
Always Keep Going :wink:
Timur
Post by Timur »
I also had this problem using XNview v.1.4.5 in Linunx Mint. I do not see change with v1.5.0, I click Never ask again but in vain, asked again.
I do not see that option in Settings.
@Timur: In Tools > Settings... > Integration -- Paths tab do you have your .ini file in User (System) or Program (XnView) ?
I'm not sure whether that could possibly be relevant and in Mint there might be a rights problem?
Silesian
Post by Silesian »
xnview wrote: Fri Jun 16, 2023 4:07 pm This problem is supposed to be fixed in XnView MP 1.5.0 beta.
The problem is in principle solved, thanks!
There is only a missing german translation:
In XnView Classic the german text was:
This text could be shorter, e.g. "Nicht erneut nachfragen".
Silesian wrote: Thu Jul 13, 2023 6:24 pm There is only a missing german translation:
Right, a translation problem
Timur
Post by Timur »
cday wrote: Thu Jul 13, 2023 3:24 pm @Timur: In Tools > Settings... > Integration -- Paths tab do you have your .ini file in User (System) or Program (XnView) ?
It is User ~/.config/xnviewmp/xnview.ini and it changed recently, so I do not think it is rights problem.
I do not know which setting is for not offering to save changes, I see "savingChanges=0"
I click "Do not ask again" and "Don't save" but I am asked again. Really annoying. I want to never be offered to save, any session.
Timur wrote: Fri Jul 14, 2023 7:25 am
The 'ask again' is kept during session
Else savingChanges=2 will not ask
