win10x64 xnviewmp 1.6.1
My bug from other topic:
viewtopic.php?p=193402#p193402
I'll write it here, too:
For permanent zoom-out setting ("high quality zoom" in F12 dialog), if set to "none" or "billinear", the temporary high quality zoom setting (Viewer - View - High quality zoom menu item) switches between "none" and "billinear". It is ok. But for permanent zoom-out bicubic-lanczos4 settings, the temporary high quality zoom "none" setting no longer works (at all). It is bug. Whereas for any zoom-in permanent settings, temporary high quality zoom works fine.
1.6.1 - Temporary High quality zoom-out bug
Re: 1.6.1 - Temporary High quality zoom-out bug
This problem is supposed to be fixed in XnView MP 1.6.2. Please check and confirm the bug fix here.
