Create a File List incl. CountryCode and Location
WulfG
Post by WulfG »
Dear all
I would like to write the contents of the fields “title”, “description”, “CountryCode” and “Location” to a .txt file (see att. jpg).
For the fields “title” and “description” I use {XMP:Title} and {XMP:Description}.
Unfortunately, I cannot find the correct XMP field names for the “CountryCode” and “Location” fields.
How and where can I find the correct field names?
Thanks for the support and help :D
Wulf
Used Software:
- Windows 11 Pro Vers. 24H2
- XnView MP Vers. 1.8.5 64-bit
Re: Create a File List incl. CountryCode and Location
WulfG
Post by WulfG »
Hello Pierre
So cool that you could fix this problem !!!
Thanks a lot.
Wulf
WulfG
Post by WulfG »
Hello Pierre
Thank you so much to fix the my request (viewtopic.php?t=48538) in Release 1.8.7.
When I create a filelist I'll get also the CountyCode and the Location.
Best Regards from Zurich
Wulf
Screenshot 2025-03-28 113952.jpg (308.56 KiB) Viewed 635 times
