Settings - read - Camera RAW - clarify settings
XnViewMP 1.8.6 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
settings for Camera RAW are poorly named and spread across the app, which is inconvenient
  • unify settings in single place
    - move 'Camer RAW, use' from View into Read>Camera RAW
  • rename
    to clarify things up
    • settings
      - 'Use for view' OR 'View'
      - 'Use for convert' OR 'Convert' OR ' Processing'
    • flags
      RAWFlag → RAWConvertingFlag
Example
Related
Re: Settings - read - Camera RAW - clarify settings
done in 187
(except tag renaming)
