1.9.3 - Search presests no longer remember the path saved with it [Solved]
MacAhi
Post by MacAhi »
I tried re-saving a Preset, but it still didn't remember the paths I saved with them.
Also, the Conditions in the search dialog are all case-sensitive, so if I'm trying to avoid searching in folders 'Keep', I also have to list it as 'keep' in case capitalization wasn't consistent.
Thanks
Re: 1.9.3 - Search presests no longer remember the path saved with it
MacAhi wrote: Wed Aug 13, 2025 12:19 am I tried re-saving a Preset, but it still didn't remember the paths I saved with them.
https://newsgroup.xnview.com/viewtopic.php?t=49438
jkm
Post by jkm »
I think saving/restoring the directory with the preset should be an option.
Forcing it is bad, but there may be situations people want to save the directory.
MacAhi
Post by MacAhi »
Thanks. That's really unfortunate that this was removed. It's going to make some of my searching take a lot more effort.. I decided to revert to 1.9.2 because of this.
"D. Allow search presets to be saved with the option "Use Current Directory". Loading such a preset with that option will not overwrite the directory already filled in in the Advanced Search dialog."
This would have been a better option.
This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
jkm
Post by jkm »
The "Save a preset" dialog now has an option to save the path with the search or not. Works great. I think this is fixed.
MacAhi
Post by MacAhi »
xnview wrote: Mon Sep 29, 2025 7:57 am This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
Very sorry for the very late response. Yes, this fix is great. Thanks!
