You can download XnView MP 1.9.4 here:
Windows x64 ZIP version SHA256: 457ADE63F4B6CB2F28E70DC7D21CFB1C43BBE9988C23865D143BCEE8B27EB305
Windows x64 SETUP version SHA256: 400DF70A512AD1E9AD99411D887ABEBAE94C782B024342508D3FAB93740EDD28
Mac x64 DMG version SHA256: 7F0F6D34121E91EDD8D00571C90571140F726DE74252695E80D116886493FD1D
Linux x64 TGZ version SHA256: 83450F781D3E1CCAFBE1CC47E6B45FED6088B5AD7211BD597B79FF94F67E7E7E
Linux x64 DEB version SHA256: 399D4E5BD6AA4BA88D8CFE318D8B8E740A5312C406BFC0AC3E042F45996B5030
ARM version: https://download.xnview.com/XnViewMP-linux-arm.tgz https://download.xnview.com/XnViewMP-li ... _armhf.deb
Linux x64 AppImages version: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.9.4:
3756: [New] Exiftool 13.37
3754: [New] Batch convert - Blurred frame - https://newsgroup.xnview.com/viewtopic.php?t=49532
3753: [New] Favorites's tab for metadatas
3746: [New] Catalog filter - Date & exif node
3737: [New] Slideshow - folder and watch folder - https://newsgroup.xnview.com/viewtopic.php?t=47446
3735: [New] Windows - ExifTool path setting
3699: [New] Settings - Mouse - Horizontal scroll - https://newsgroup.xnview.com/viewtopic.php?t=47176
3755: [Bug] Crash with some formats - https://newsgroup.xnview.com/viewtopic.php?t=49598
3752: [Bug] Batch convert - RAW setting - https://newsgroup.xnview.com/viewtopic.php?t=49189
3751: [Bug] Paste improved in edit mode
3750: [Bug] Custom sorting not used in View mode - https://newsgroup.xnview.com/viewtopic.php?t=49581
3749: [Bug] Filter by tag - viewer - https://newsgroup.xnview.com/viewtopic.php?t=49562
3748: [Bug] Batch convert - Output folder field allows folder name with trailing space - https://newsgroup.xnview.com/viewtopic.php?t=49582
3747: [Bug] Exiftool process stays after crash
3745: [Bug] Quick search not cleared after selectin a category filter
3744: [Bug] MacOS x86 - https://newsgroup.xnview.com/viewtopic.php?t=49453
3743: [Bug] Browser - category sets - pane min width depends on combobox - https://newsgroup.xnview.com/viewtopic.php?t=49561
3742: [Bug] Browser - context menu - convert into - sort items - https://newsgroup.xnview.com/viewtopic.php?t=49559
3741: [Bug] Browser - Crash after rename and fullscreen - https://newsgroup.xnview.com/viewtopic.php?t=49542
3740: [Bug] Category - slow on lot of files but minor change - https://newsgroup.xnview.com/viewtopic.php?t=49523
3739: [Bug] Search - catalog - empty folder field - https://newsgroup.xnview.com/viewtopic.php?t=49538
3738: [Bug] Update catalog from files - empty selection - must work on all files
3736: [Bug] Search - Pathname - case sensitive - https://newsgroup.xnview.com/viewtopic.php?t=49520
3734: [Bug] MacOS - Folders - no sort after drag and drop - https://newsgroup.xnview.com/viewtopic.php?t=49292
3733: [Bug] Quick search - XMP - https://newsgroup.xnview.com/viewtopic.php?t=49502
3732: [Bug] Viewer - auto zoom - resets to No fit - https://newsgroup.xnview.com/viewtopic.php?t=48453
3731: [Bug] MacOS - greyscale jp2000
3730: [Bug] Thumbnails for SVG files
3729: [Bug] Rating - custom name - https://newsgroup.xnview.com/viewtopic.php?t=49501
3728: [Bug] Edit IPTC - thumbnail labels not updated - https://newsgroup.xnview.com/viewtopic.php?t=49487
3727: [Bug] Enhance colors - tab order - https://newsgroup.xnview.com/viewtopic.php?t=49489
3711: [Bug] Browser - detail - fnumber - https://newsgroup.xnview.com/viewtopic.php?t=49323
3726: [Bug] Categories management - export - description - https://newsgroup.xnview.com/viewtopic.php?t=49335
3725: [Bug] Detail view - dpi
3724: [Bug] Search - select file in browser - https://newsgroup.xnview.com/viewtopic.php?t=49460
3723: [Bug] Search - preset - save pathname - https://newsgroup.xnview.com/viewtopic.php?t=49472
3722: [Bug] Edit XMP - placeholder in subject - https://newsgroup.xnview.com/viewtopic.php?t=49473
3702: [Bug] Batch convert - nconvert - webp - https://newsgroup.xnview.com/viewtopic.php?t=49317
3721: [Bug] File in writing doesnt appear - https://newsgroup.xnview.com/viewtopic.php?t=49387
3720: [Bug] MacOS - problem to send email
XnView MP 1.9.4
XnView MP 1.9.4
