Custom sorting not refleced in View mode
B.Douille
Post by B.Douille »
Hello, can you have a look at this ?
After manually sorting a set of picture I wanted to see them one by one in view mode. Doing so the pictures are not displayed in the same order I put them. It's more or less the same order as before I sort them manually. However, in full screen it's ok.
A workaround is to press F5 in the browser view. Nothing visible happens but it seams there is a need to refresh a cache somewhere.
Browser tri manuel - bug in iew mode.jpg (80.56 KiB) Viewed 1169 times
Daniel, happy user to manage photo and videos and show them in slideshows for 20 years (Windows 11, Linux Ubuntu and Android)
Re: Custom sorting not refleced in View mode
looks like Viewer uses .XnViewSort file, but Browser tab delays writing updates there until: F5 pressed, folder changed, or Browser tab closed.
I would write updates to .XnViewSort file right after each manual reordering event as I doubt user can do it fast enough to cause any noticeable i/o delay
B.Douille
Post by B.Douille »
Exact. I see the file not updated in real-time after rearranging the pictures. This is missing as well when a file is added or deleted.
Also, if a file is deleted and the focus is set to another folder the hidden .XnViewSort file keeps record of the (now missing) file for the next visit.
Strange is the full screen mode is not impacted and follows the user's sort order. Same if you start a slideshow. Selecting all files with CTRL-A the pictures are on the right sort order.
So there is another cache that keep right track of the manual reordering.
I've forgotten to mention I use the latest MP v1.9.3 under Windows 11
This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
B.Douille
Post by B.Douille »
Fixed :)
Merci
