1.9.3 Batch convert - Output folder field allows folder name with trailing space
tvcat
Post by tvcat »
XnView: MP 1.9.3 - 64 bit
OS: Windows 10/11 64bit
Folder name with trailing space is technically allowed on Windows, but the user cannot delete, copy, move or rename a folder that has a name with tailing space via the Windows Fire Explorer or the usual command in command prompt.
Not sure about other similar input field. I'm expecting XnView MP to run a check to the folder/file name before creating it.
The only way I know to delete a folder that has a name with tailing space is by adding
at the front of the full path of the folder in command prompt.
Effect:
1. Select some image.
2. Open batch convert.
3. Select an output folder.
4. Edit the output folder field by adding a new folder name that has a trailing space.
Actual behaviour (bug): XNView MP created a folder name that has a trailing space.
Expected behaviour: XNview automatically remove the trailing space of the output folder name upon folder creation.
Re: 1.9.3 Batch convert - Output folder field allowed folder name with trailling space.
Post by michel038 »
Now, I understand why some strange folders appeared in my photos when using XnViewMP...
To delete a file or a folder whose name is incorrect, you can also use it's short name shown with dir /X command.
Re: 1.9.3 Batch convert - Output folder field allows folder name with trailing space
This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
tvcat
Post by tvcat »
xnview wrote: Mon Sep 29, 2025 8:01 am This problem is supposed to be fixed in XnView MP 1.9.4. Please check and confirm the bug fix here.
Sorry for the late reply. I can confirm that it is fixed in version 1.9.4.
Thanks for your work.
