Edit EXIF: Focal Length can't exceed 100mm
Bugs which are supposed to be fixed in the next test version (not available yet)
jkm
Post by jkm »
There is a defect in the Metadata->Edit EXIF dialog.
The Focal Length entry field will not accept any value greater than 100mm.
That's absurd. Lenses > 100mm are common.
The field must accept 4 digit focal lengths, <=9999mm (plus the decimal place, as lenses with lengths like 37.5mm do exist)
Re: Edit EXIF: Focal Length can't exceed 100mm
