File Size in FILE NAME details listings
uncpotato
(1)
I would like to see the File Size is RIGHT JUSTIFIED.
Currently it is left justified seems very odd to me.
(2)
Secondly, is there an option so I can see the file size in actual bytes??
I sometimes have sized-down thumb nails saved in the same folder, I lost my sense of big files versus small files seeing sizes in MB/KB.
A column like this is hard to tell:
IMG_2627.JPG 3.56 MB
IMG_2628.JPG 3.78 KB
IMG_2629.JPG 2.97 MB
IMG_2630.JPG 4.38 KB
I would like to see something like:
IMG_2627.JPG 3,563,678
IMG_2628.JPG 3,780
IMG_2629.JPG 3,063,789
IMG_2630.JPG 4,980
(2)
IMG_2628.JPG 3,780
IMG_2630.JPG 4,980
uncpotato
Re: File Size in FILE NAME details listings
Yes perhaps better...uncpotato wrote:(1)
Currently there is no way to customize details view...(2)
IMG_2628.JPG 3,780
IMG_2630.JPG 4,980
Danny
http://newsgroup.xnview.com/viewtopic.php?t=4081
In other words: yes, i'd like to have that as well.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
What about right aligned columns:
IMG_2628.JPG 3,780
IMG_2630.JPG 4,980-
uncpotato
WOW...Danny wrote:http://newsgroup.xnview.com/viewtopic.php?t=4081
seeing a requested feature back in year 2005 and still on the wish list is really cool... And most of all, it is not something that is hard to implement. Take no more than 10 minute to change the code.
Yes, very easy, but some users want to see it in Kb or Mb and not in bytes...uncpotato wrote:WOW...Danny wrote:http://newsgroup.xnview.com/viewtopic.php?t=4081
uncpotato
No, No, No..... I suggest to *ADD* an option to show in bytes (in addition to existing KB/MB/GB, which many other users like). This addition will take, as suggested in my previous post, 10 minutes to program.xnview wrote: Yes, very easy, but some users want to see it in Kb or Mb and not in bytes...
Otherwise, if just changing from KB/MB/GB into just actual byte might just take 10 seconds to finish...
- Forum Librarian
XnTriq ([url=http://newsgroup.xnview.com/viewtopic.php?p=45785#45785]Format of <Size> variables[/url]) wrote:For thumbnail labels & tooltips as well as HTML output and the information shown in fullscreen mode I prefer the <Size> over the <Size KB> variables.
My request would be that the values for <Size> are formatted as 1.234.567 bytes rather than 1234567 bytes to make them easier to read.
Danny
It's great to have this now. But, you've guessed it, i have some problems.
First of all: it's wrong. The column always says bytes, even if the file is much bigger.
Having the size column left aligned makes it hard to read and to get an overview with one look. So i would like to have it right aligned when size is being displayed in bytes like in that post by Helmut.
The other thing is that you spelled out bytes. That takes a lot of room and makes the size column very wide. That's bad, especially since the number will get really big, if the filesize is beyond 1MB. So it should read "B" for bytes (and NOT "b" since the small letter is commonly used for "bit" size.
Danny
Example:xnview wrote:Sorry but i do'nt understand???Danny wrote: First of all: it's wrong. The column always says bytes, even if the file is much bigger.![]()
If there's a file, which is 100 kBytes big, it says 100 bytes in the size column of the details view, instead of 100.000 Bytes.
??? Really, i have not this bug!Danny wrote:Example:xnview wrote:Sorry but i do'nt understand???Danny wrote: First of all: it's wrong. The column always says bytes, even if the file is much bigger.![]()
- Forum Librarian
Danny
