Flash Plugin - doesn't work at all
Dreamer
Post by Dreamer »
Directory cannot be selected, there is probably wrong dialog - select file instead of folder. Also possibility to type manually/past path is missing. Therefore it doesn't work at all now.
Edit: It is possible to select a single file/image, then this dialog is shown:
"Save as...
D:\...name.jpg already exists.
Do you want to replace it?"
When I select Yes, the file is added to Directory field, OK, but I don't know if - and what is saved - and where. I don't think any file is saved.
v1.91.2, Win XP SP2.
Dreamer
Re: Flash Plugin - doesn't work at all
Dreamer wrote:Directory cannot be selected, there is probably wrong dialog - select file instead of folder. Also possibility to type manually/past path is missing. Therefore it doesn't work at all now.
"Save as...
Right, a little problem, you must select a new file, not a directory.
Dreamer
Post by Dreamer »
But even if you select a file, it doesn't work. :?
Dreamer
Moderator & Librarian
Dreamer wrote:But even if you select a file, it doesn't work. :?
Confirmed :bugconfirmed:
Dreamer, do you have JPEG files with a .tmp extension (x_[0-9, A-F][0-9, A-F].tmp) in your system's %TEMP% folder after each attempt to export non-JPEG (BMPs, GIFs, PNGs etc.) images to Flash?
____________________________
XnView 1.91.2 · Windows 2000 SP4
For else…
—> XnTriq
:) Hello Mr. Librarian !
Dreamer, do you have JPEG files with a .tmp extension (x_[0-9, A-F][0-9, A-F].tmp) in your system's %TEMP% folder…
• YEP ! I've such kind of files in another case since 1.9.2, and that's VERY ANNOYING:(
- I don't know if this is related or not, but there is a hitch in the “temp” thingy management, for sure…
:mrgreen: KR
Dreamer
Post by Dreamer »
No, I don't. :? I tried gif and bmp.
Dreamer
Dreamer
Post by Dreamer »
You said it should be fixed in v1.91.3, but I still have a file dialog, not a folder. :?
I'm using a full zip version.
Dreamer
Dreamer wrote:You said it should be fixed in v1.91.3, but I still have a file dialog, not a folder. :?
Yes, but it works
Dreamer
Post by Dreamer »
I see how it works now, but it's really confusing, I thought "Directory" means a directory for image files, but it's a destination path for swf.
"Directory" should be changed IMO, to "Save to", or "Destination".
Dreamer
