Sorting Gifs: Animated, multi image, Fix
brotondi
Post by brotondi »
A way to sort gifs would be nice: Animated, Multi-Image, Fix
Perhaps easiest way: Add "Infos" in Detailview which can be used for this Info and others. Sorting by this Column then solves the Problem.
Another way, only a help: Properties = "50x50,256 (animated)" or "... (multi image)"
... Interesting for someone else?
Thanks!
Bruno
oops66
Re: Sorting Gifs: Animated, multi image, Fix
Post by oops66 »
brotondi wrote:A way to sort gifs would be nice: Animated, Multi-Image, Fix
Thanks!
Bruno
An other way, is to use categories (already implemented in Xnview).
Animated cursors are easily distinguishable from regular cursors: They have different file extensions (ANI vs. CUR). With formats like GIF you won't know unless you view the file. The same goes for TIFFs or PSDs: Only when a document is opened will XnView tell the user that “this image contains multiple pages. Please use ‘Previous page’ and ‘Next page’ to navigate between the pages.”
XnView needs an animation overlay icon and/or multi-page indicator*. (In ThumbsPlus they're called “decorations”.)
  • Animations
    • GIF vs. Animated GIF
    • PNG vs. Animated PNG
  • Multi-page documents
    • TIFF
    • DjVu
  • Layered documents
    • Photoshop
    • Paint Shop Pro
*Tools » Options... » Browser » Thumbnails » Icon info » File info
Xyzzy ([url=http://newsgroup.xnview.com/viewtopic.php?t=4941]Options' descriptions for 1.82[/url]) wrote:Show info icons – If checked, overlays small info icons on thumbnail. Avaliable info icons are: EXIF data present, IPTC data present, embedded thumbnail used, image rotated using EXIF info.
And also---
:arrow: XnTriq
:) Hello !
…Multi-page documents
• TIFF
• DjVu
… and also :
*.ICO
*.DCX
*.LDF (Luratech)…
• When discussing about the A-PNGs, I noticed already that it's the same extension,
hence it's impossible to distinguish them from the simple PNG pics ;)
- An overlay icon should do the trick, without flooding the thumb nail bottom,
since the most concerned formats have not any Exif and the like…
• Well, three pages more here in sight (at least) to find the right icon ! Image
:mrgreen: KR
Re: And also---
• TIFF
• DjVu
… and also :
*.ICO
*.DCX
*.LDF (Luratech)…
I'm counting on your help to find every last one of 'em. :wink:
Clo wrote:An overlay icon should do the trick, without flooding the thumb nail bottom,
No one wants the thumbnails to be cluttered with info icons. Users should be able to turn them on and off individually.
Clo wrote:Well, three pages more here in sight (at least) to find the right icon ! Image
Oh yes, it's going to be a wild ride. :mrgreen:
