Flash Export AddOn
Sabine T
Flash Export AddOn
Post by Sabine T »
xnview wrote:I've added a plugin to create Flash file from pictures, and export to ImageShack
I did not find any further information about the FLASH EXPORT AddOn.
... could you please explain the usage?
o.k. it makes a *.sfw file of a picture, but what is the "delay" funktion for? it blinks (for example every 2 seconds) - is it the only purpose?
Or are there more possibilities to use it?
Yours, Sabine
Re: FLASH EXPORT
Sabine T wrote:I did not find any further information about the FLASH EXPORT AddOn.
Sabine T
I would still like to know more about "Flash export&quo
Post by Sabine T »
thanks for your answer XnTriq,
but to be honest, it didn't help me. sorry.
the german translation of the link is ridiculous, i do not understand anything :(
Escurial wrote:gut guten Tag geben ich mir auf dem
Forum in englischer Sprache zurück, und habe diese Seite aufgedeckt:
Addons/Plugins/...
. Nachdem ich téléchargé das gesetzte addon
"flash.zip", das "Allows to create flash file from pictures" und habe,
die Karteien im Register ' addon ' (et non addons), ich habe
XnView angekurbelt, um Kurznachrichtenkarteien..., aber ohne Erfolg zu
schaffen. Was zu machen, um eine Kurznachrichtenkartei zu
schaffen, die mehrere Photos zurücknimmt?
I would like to know more about the usage of "Flash export".
for example: is it possible to put more than one picture into a [swf]-flash-file?
if yes - how?
if no - what is the "delay" funktion for?
Yours, Sabine :|
Re: I would still like to know more about "Flash export
Hello Sabine :)
What I ment to say by posting those two links was, that there is very little information available on how the plug-in works.
Try this:
  1. In Browser mode, select several (preferably same-sized) images.
  2. Go to Tools » Plugin » Flash (1.01).
  3. Choose a filename for your Flash animation.
  4. Delay lets you specify how many seconds each image should be displayed before the animation jumps to the next frame.
Is someone out there who knows what exactly the Maximum size setting does?
YES !!!
:arrow: XnTriq
:) Hello !
…Is someone out there who knows what exactly the Maximum size setting does?
• YES, there is one ! He's so-named Pierre-Emmanuel GOUGELET ! Image
:mrgreen: KR
Same opinion !
:arrow: Sabine T
:) Hello Sabine !
…the german translation of the link is ridiculous, i do not understand anything :(
•Ah-ah ! About the same topic, I wrote a while ago the same remark HERE :
»The “French” text from Babelfish is totally ridiculous, it's impossible to understand anything from that !
To avoid, please…«
:wink:
:mrgreen: VG
Re: Same opinion !
To avoid, please…«
:wink:
:twisted: Sue me! (en»fr)
Post by Guest »
XnTriq wrote:Try this:
Hi XnTriq!
Thanks for your explanation ... IT WORKS the way you describe it.
First I thought, "maximum sice" would set a maximal zoom ratio for the flash display in a browser, but it ain't so.
Maybe Pierre will tell us more :wink:
But there is something like a bug, maybe there is a way to fix it:
the flash picture is not displayed centered, it is displayed in the right down corner, when you look at it in a player or a browser.
I woukld like to use it in a HTML page, but without a white frame on the left and upper side.
yours Sabine :)
