Hello, everyone.
I've been photographing some of the atlas required on my work.
the thing is that is xnview capable of previewing two photos at the same time?
and when i pushed page down to change it automatically load another two.
acting like turning pages in a book.
sorry, i don't really know how to call this function.
i just know that in acrobat reader they have a function for users to read pdf files in which two pages show side by side at the same time.
thanks alot
view two photos at the same time
- Forum Librarian
J Smith
Note a system for viewing two photos independently
This posting below describes a system for viewing "two photos" but viewing two separate photos independently in two or more different directories navigated independently and permits you to view thumbnails in two directories concurrently.
A Dual Panel XnView System
http://newsgroup.xnview.com/viewtopic.php?p=46756#46756
Foxit PDF reader refers to the function in the posting as "facing." On the view menu, under page layout, it provides 4 options: single page, continuous, facing, and facing continuous. The context there is within a file.
To describe the request in the posting and the other thread above, I would propose the term "open mode." That would refer to the number of images opened when you open a file, or click a thumbnail. Now when you click on a thumb nail, you open 1 file. You could have options of 1, 2, 3, 4, etc. When you clicked on a file, the system would open that file and the next 1, 2, 3, or 4 files facing displayed on one screen. As you clicked on next or previous file, you would move to the next set or !, 2, 3, 4, etc. This sounds like a good idea to me.
Note that you can also display multiple photos simply by opening them and then using windows tile horizontal or vertical commands.
