Wish: special mark for CMYK images
Micha
Post by Micha »
could it be possible that CMYK image thumbnails get a special mark, so that the can be found easy. For example a colored frame or a small "CMYK" label?
Ciao,
Micha
Troken
Post by Troken »
In that case you'd have to consider other colorspaces too, i.e. Lab, greyscale etc.
Micha
Post by Micha »
Good idea!
Micha wrote:could it be possible that CMYK image thumbnails get a special mark, so that the can be found easy. For example a colored frame or a small "CMYK" label?
Sorely missed feature!
Troken wrote:In that case you'd have to consider other colorspaces too, i.e. Lab, greyscale etc.
... and embedded color profiles ;-)
Troken
Post by Troken »
Im thinking, instead of having a new symbol for these things, could it be possible to have a customised thumnail label for it? Then you could decide for yourself what kind of information about colorspace and ICC-profiles you want to add.
Thumbnail labels have great potential, and every user can adjust them after taste and needs. For me this solution would be awesome.
Micha
Post by Micha »
Sounds good. For me too please. :wink:
