I would like a way to quickly display a quicker slideshow without the slideshow configuration screen coming up. Currently you select files and then another screen shows where you need to look at all the configuration setup and then hit "go" before it displays. If the slideshows are the same every time it makes it easier to just press a hotkey or a button to display a new slideshow with whatever files and folders were selected and have it run based on the previous settings instead of the configuration screen showing up first. That would be very useful when presenting one slideshow after another.
Thank-you.
Quick Slideshow
- Forum Librarian
